Iterate Code By Element Type
ebsoares
Message 1 of 9
ebsoares
Hi, everyone.
Would like to learn how to iterate through types of selected elements with Lisp code.
Suppose we've got a selection set containing blocks, texts, and mleaders. Now how would we write code to do this:
(selection set with blocks, texts, and mleaders)
    (go through both blocks and texts)
        (do this with blocks and texts)
    (go through mleaders)
        (do this with mleaders)
Any help would be greatly appreciated!
Edgar
Replies (8)
Message 2 of 9
Ranjit_Singh
@ebsoares wrote:
Hi, everyone.
Edgar
There are probably many ways. Use repeat, while, foreach (ssnamex will convert selection set to list) etc. Cond is another option
(cond
((= (cdr (assoc 0 (entget ent))) "MULTILEADER") (. . process multileaders. .)) (t (. .for everything else do this. . .)))
ent is the subject entity in selection set and I assumed that you have no other type of entity (except mleader, insert and text) in there. If you are unsure, then add one more test block in the cond to test for insert/text and then add a t to catch everything else
Message 3 of 9
ebsoares
Hi, Ranjit. Thanks coming to the rescue again 🙂
I've used the cond code you mentioned (I like those), but it doesn't work - it goes as far as asking for the angle, but then it give me an error message: "; error: bad argument type: lentityp nil".
Here's the code I have - the blue is from the code you wrote, the red is what I'm trying to do each time:
(defun c:RotMultBase ( / ss ang )
    (vl-load-com)    ; start VLisp
    (setq ss (ssget "_:L" '((0 . "Insert,Text,MText,MultiLeader"))))
    ; Main code
    (setq ang (getangle "\nSpecify Rotation Angle: ")) ; allows for 2-point cursor input
    (cond
        ((= (cdr (assoc 0 (entget ent))) "MultiLeader") ; isolate multileaders and do the following:
            (mapcar '(lambda (x) (setpropertyvalue x "MText/Rotation" (+ (getpropertyvalue x "MText/Rotation") ang)))
                (vl-remove-if 'listp (mapcar 'cadr (ssnamex ss)))
        (t ; for the rest (Insert,Text,MText), do this:
                (lambda ( i / e o )
                    (while (setq e (ssname ss (setq i (1+ i))))
                        (vla-put-rotation (setq o (vlax-ename->vla-object e))
                            (+ (vla-get-rotation o) ang)
                -1
    (princ)
Each code works individually - the one you made (and dbroad) and the one that rotates blocks, texts, and mtexts (from Lee Mac). I'd just like to have them in a single set of code...
Any chance you can spot where I made a mistake?
Edgar
Message 4 of 9
Ranjit_Singh
You are processing the selection sets twice in each block in cond and also ent is not defined. Plus there are other issues. See if you can use this. I have not tested.
(defun c:rotmultbase  (/ ent ss ang i)
       ss  (ssget "_:L"
                  '((0 . "insert,text,mtext,multileader")))
       i   -1)
 (while (setq ent (ssname ss (setq i (1+ i))))
  (cond ((= (cdr (assoc 0 (entget ent)))
            "MULTILEADER")
         (setpropertyvalue ent
                           "MText/Rotation"
                           (+ (getpropertyvalue ent "MText/Rotation")
                              ang)))
        (t
                           "Rotation"
                           (+ (getpropertyvalue ent "Rotation")
                              ang)))))
 (princ))
Message 5 of 9
ebsoares
Thanks for that, Ranjit.
For some reason, it only worked with blocks, but it ignored the others in the selection set, and gave me an erro message: "; error: ADS request error".
Also, this iteration does not work with existing selections, like the previous codes - If there's anything selected, it deselects them, then asks for an angle input, then asks for a brand new selection.
Message 6 of 9
Kent1Cooper
You could try something like this:
    (setq ss (ssget "_:L" '((0 . "Insert,Text,MText,MultiLeader")))); from yours
    (setq ssML (ssget "_P" '((0 . "MultiLeader")))); separate set of just the MLeaders from the full set [Previous selection]
    (sssetfirst nil ss); re-establishes full ss as "Previous" for next (ssget)
    (command "_.regen"); un-highlights [may be expendable, depending on what you do subsequently]
    (setq ssBT (ssget "_P" '((0 . "Insert,Text,MText")))); separate set of just the Blocks/Text
Then you have each category in its own separate selection set that you can process in its own way.
Kent Cooper, AIA
Message 7 of 9
Ranjit_Singh
I accidentally reversed the order of setq for ang and ssget. See if reversing it helps.
        i   -1)
            "MULTILEADER")
                           "MText/Rotation"
                              ang)))
        (t
                           "Rotation"
                              ang)))))
 (princ))
Message 8 of 9
ebsoares
Wow, thanks for the explanation, Kent!
I ended up using Ranjit's code (thanks again, Ranjit!), but yours already gave me some ideas for new ones.
And I eally appreciate you taking the time to explain the code - that's priceless Smiley Happy
Edgar
Message 9 of 9
ebsoares
Ranjit, your code works fantastically - everything is just as expected!
Really appreciate you giving off your time to help me on this Smiley Happy
Edgar
