is there any way to create vertical construction line on selected polyline all vertices
7aizur
Message 1 of 18
7aizur
Here is a sample image where I want to add automatically construction line on all vertices with the help of lisp or any other way.
TIA
Replies (17)
Message 2 of 18
ВeekeeCZ
Easy enough.
(vl-load-com)
(defun c:VerAtVer ( / s)
  (and (setq s (car (entsel "\nPolyline: ")))
       (setq s (vl-remove-if '(lambda (x) (/= 10 (car x))) (entget s)))
       (foreach v s (entmake (list '(0 . "XLINE") '(100 . "AcDbEntity") '(100 . "AcDbXline") v '(11 0. 1. 0.)))))
  (princ)
Message 3 of 18
Kent1Cooper
For as many as you want to select, all at once, including "heavy" 2D and 3D Polylines [not just LWPolylines]:
(vl-load-com)
(defun C:XLVAPV (/ plss n pl v); = XLines Vertical at All Polyline Vertices
  (prompt "\nTo draw Vertical Xlines through All Polyline Vertices,")
  (if (setq plss (ssget '((0 . "*POLYLINE"))))
    (repeat (setq n (sslength plss))
      (setq pl (ssname plss (setq n (1- n))))
      (command "_.XLINE" "_ver")
      (repeat (setq v (+ (fix (vlax-curve-getEndParam pl)) (if (vlax-curve-isClosed pl) 0 1)))
        (command "_non" (vlax-curve-getPointAtParam pl (setq v (1- v))))
      (command "")
  (princ)
[It will "do it" on a Spline-fitted Polyline, though the Xlines will not be at the positions of its pre-Splined source vertices except at the ends.]
Kent Cooper, AIA
Message 4 of 18
7aizur
Thanks for the code but can you kindly tell me where to use the code?
Message 5 of 18
Kent1Cooper
For starters, to try it, you can just Ctrl+C copy it to the clipboard and Ctr+V paste it into a drawing at the Command: line, and hit Enter to "register" the closing right parenthesis when it looks like this:
Type the XLVAPV command name to use it.  [You can change the command name if you like.]
If it works as you intend, paste the code into a plain-text editor such as Notepad.  Save it as a file called whatever you like but with a .lsp filetype ending.  [It's best to put it in some folder location in the list in the OPTIONS command, Files tab, under Support File Search Path, preferably one with ...\support at the end.]  In AutoCAD, use the APPLOAD command, navigate to where you saved it and Load it.
Kent Cooper, AIA
Message 6 of 18
7aizur
Thanks for the code 😄
Message 7 of 18
7aizur
Thanks for your help ❤️
Message 8 of 18
Kent1Cooper
You're welcome.  I added the (vl-load-com) line at the top that should be there if you don't always have (vl...) functions loaded.  And it could use "the usual enhancements" like command-echo suppression and *error* handling.  Other things could be incorporated, e.g. to put them on a specific Layer [and make that if it doesn't exist], etc.
Kent Cooper, AIA
Message 9 of 18
ronjonp
Solved HERE too .. mine creates an "XLINE" layer and sets it to not plot too 🙂
Message 10 of 18
Sea-Haven
Message 11 of 18
Kent1Cooper
@Sea-Haven wrote:
Posted here also ....
The same one as linked in Message 9.  Also limited to LWPolylines only.
Kent Cooper, AIA
Message 12 of 18
calderg1000
Regards @7aizur
Please try this code
(defun c:Xp_pol2 (/ sn i pt)
  (if
    (setq sn (vlax-ename->vla-object (car (entsel "\nSelect. Lwpolyline: "))))
     (repeat (setq i (1+ (fix (vlax-curve-getendparam sn))))
       (setq pt (vlax-curve-getpointatparam sn (setq i (1- i))))
       (entmake (list '(0 . "Xline")
                      (cons 100 "AcDbEntity")
                      (cons 100 "AcDbXline")
                      (cons 10 pt)
                      (cons 11 '(0. 1. 0.))
Carlos Calderon G
>Did you find this post helpful? Feel free to Like this post.
Message 13 of 18
_Tharwat
Your codes have three issues:
1- If a user selected object other than polyline.
2- If a user missed the object.
3- If selected polyline is closed, then there will be double vertical lines at the common start / end point.
Message 14 of 18
calderg1000
Regards @_Tharwat
Here I made some small adjustments, exclusive for open or closed Lwpolylines. I know that the Vl-remove-if and foreach approach would save me a few steps, but I wanted to try with parameters. It is likely to run faster with many vertices.
(defun c:Xp_pol0 (/ sn i pt)
  (princ "\nSelect Lwpolyline: ")
  (if (and
        (setq s (ssname (ssget "_+.:E" '((0 . "lwpolyline"))) 0))
        (if (= (cdr (assoc 70 (entget s))) 1)
          (setq c 0)
          (setq c 1)
    (repeat (setq i
                   (+ c
                      (fix (vlax-curve-getendparam (setq sn (vlax-ename->vla-object s))))
                     (cons 10 pt)
  (princ)
Carlos Calderon G
Message 15 of 18
7aizur
Thanks, dear for the code ❤️
Message 16 of 18
Sea-Haven
For others look at post 10 link again further explanation of what is really wanted.
Message 17 of 18
calderg1000
Dear @7aizur
Glad to hepl...!!!
Carlos Calderon G
Message 18 of 18
Kent1Cooper
Just for your information, (vlax-curve-...) functions do not require conversion of entities to VLA objects -- they will also take just the entity name [as in Message 3]:
  (fix (vlax-curve-getendparam s))
and of course replacement of 'sn' with 's' later where parameter values are pulled.
In some routines the VLA-object conversion is needed for other reasons, so it can be appropriate, but it's not needed for something like this.
Also, if you're using parameter values, instead of the 10-code entries in entity data, then there's no reason to restrict it to LWPolylines [also as in Message 3]:
....  '((0 . "*polyline"))) ....
Kent Cooper, AIA
