is there any way to create a specific rectangle
yairMSKTU
yairMSKTU
lets say i have 3 lines,  each goes to a different direction the would create 2 triangles stuck together  (not nessesserily 90 degrees, but can be),
can i make a rectangle with the lines 'support' it, but the lines will NOT touch the corners ?             obviously, the rectangle can be on countless of different sizes and angle,       but i want to decide that.
is there a command to do it ?   obviously i can do it on the regular lines and offsets,  but im looking for shorter ways, if exist.
ВeekeeCZ
You should probably post an image to better visualize the issue.
imadHabash
Would you please attache an image for the shape that you want to do ?
Imad Habash
Kent1Cooper
I agree that an image would help us understand what you're looking for.  But on the chance that these might be at least related to it, I offer two routines in the same thread:
>Smallest Rectangle orthogonally oriented<
>Smallest Rectangle at any angle<
Kent Cooper, AIA
