Is There a Way to Increment the Selection Set Name in a Loop
mgorecki
Message 1 of 10
mgorecki
For example I have a number of rectangular polylines on a layer.  The groups of rectangles have different sizes.  I'll ask the user to select a group and I want to store them in a unique selection set name, then loop and have them select the next set and store them in a unique selection set name, and so on.
Any ideas on how to do this?
Replies (9)
Message 2 of 10
Kent1Cooper
This is a job for the (set) function, in which you can construct a variable name involving other functions.  In your description:
(setq n 0)
(while
  (set (read (strcat "ss" (itoa (setq n (1+ n))))) (ssget '((0 . "LWPOLYLINE") (8 . "YourLayerName"))))
That will save the first selection to a variable called ss1, the next to ss2, etc.
Kent Cooper, AIA
Message 3 of 10
komondormrex
list 'em like that
(setq sset_list nil
      loop t
(while loop
	(setq sset_list (append sset_list (list (ssget))))
and then get each sset usins nth function.
(sssetfirst (nth 0...n  sset_list))
Message 4 of 10
mgorecki
Hi Kent, thank you very much!
Message 5 of 10
mgorecki
Thank you very much as well, I though about using a list.
Message 6 of 10
komondormrex
your welcome. it is LISt Processing)
Message 7 of 10
Sea-Haven
Any reason why you would not make a list ( (layer entityname)(layer entityname)(layer entityname)....
The list could have even more items (layer entityname area length) etc. You can sort the list based on any sub item.
Message 8 of 10
Kent1Cooper
[Nothing in the request relates to Layers.]  A big difference:  my solution puts entire selection sets, of any number of objects, not just one entity, and on any number of Layers, into incremented-name variables [see the Topic heading].  But the OP would have to say whether that list approach can serve their purpose.
Kent Cooper, AIA
Message 9 of 10
mgorecki
And here I thought it stood for Lost In Stupid Parenthesis 😄
Message 10 of 10
mgorecki
Hello, no particular reason except that I just wanted to have different selection sets to manipulate later in the code.  I agree, Lists are very helpful, I use them a lot.
