Is it possible to remove vertices from a hatch with lisp?
jamieq
Message 1 of 21
jamieq
I'm writing a lisp function that will include removing hatch vertices, but I'm having some trouble. With a polyline you can remove a vertex and the other associated entries from the object's entities and then entmod. That doesn't work with a hatch. In fact, a hatch's entities list seems like it can be a couple different ways. If the hatch was made by selecting an object, then the sides between vertices (for lines only, arcs are quite different) are listed with a (72 . 1) then a DXF code 10 point and DXF code 11 point. If the hatch was made by selecting a point, then the vertices are listed as a series of DXF code 10 points. My thinking was if I removed the appropriate items from the list of entities and then ran entmod on that new list, the hatch would update without the removed vertex/vertices. But this doesn't happen. Instead I just get a return of nil. Is there a way to actually do this by entmodding?
I've tried a couple other ways, including recreating the hatch boundary, modding that pline, then disassociating the hatch and deleting the pline. But if the hatch has multiple boundaries, or any internal islands, it all falls apart as multiple plines are recreated and it just becomes a big giant mess. So I'm hoping there's another way I can do this an easier way.
Replies (20)
Message 2 of 21
pendean
Community Legend
Community Legend
How do you want to pre-determine which vertices to remove from these hatches exactly (and which to keep)?
Message 3 of 21
jamieq
Possibly by getpoint selection, or maybe by vertices within a window. For purposes of this conversation, let's just assume I have a point that matches a hatch vertex and I'm trying to remove that vertex from the hatch.
Message 4 of 21
hak_vz
@jamieq
You don't need lisp for this.
Start command HATCHEDIT, use option to recreate hatch boundary as a polyline, and make hatch associative to recreated polyline boundary. Click on recreated (or already existing boundary polyline), and hover over vertex you want to remove. Dialog pops up with options to stretch, remove or add vertex. After you remove some vertex, hatch entity will update automatically.
Working with hatch entity is complex in autolisp, especially using dxf codes, since there are different types of hatches,
Miljenko Hatlak
Message 5 of 21
jamieq
I appreciate the reply, but I'm trying to do this specifically with lisp.
Message 6 of 21
hak_vz
(command "-hatchedit" OBJ "b" "r" "y")
Use this for start, make hatch object associative to poylyline and create code to add or remove polyline vertex.
Miljenko Hatlak
Message 7 of 21
Kent1Cooper
I think you want the recreated Boundary to use the Polyline option in there, not the Region option.  Regions have utterly inscrutable entity data, and I don't think vertices in them can be manipulated in AutoLisp.
Kent Cooper, AIA
Message 8 of 21
jamieq
Again, I appreciate the reply, but that's exactly how I've already implemented it. I mentioned in the original post that I've used that method. The problem is, if the hatch has multiple boundaries or any internal islands, then that method gets super messy really quick. When the hatch boundary is recreated, each boundary is a new pline. And if more than pline is created, it becomes difficult to get entities before entlast, since deleting entlast to get the second to last entity destroys the hatch association.
That said, while writing this reply, I read another forum thread about working backwards from entlast, and someone suggested setting a bookmark with entlast before creating new entities then using entnext from the bookmark. So that's exactly what I'm going to do so I can capture all the boundary plines that come from recreating the boundary.
Message 9 of 21
john.uhden
INSCRUTABLE.  That's the perfect word!
Nice, @Kent1Cooper .
John F. Uhden
Message 10 of 21
Kent1Cooper
INDUBITABLY!
Kent Cooper, AIA
Message 11 of 21
jaruugarte
hi @jamieq
looking for a solution, I found these two files that manage to do what you ask, but it is in two steps that it is achieved.
with "HTCHEDIT" command recreate the boundary off the hatch, and with the "addv.vlx" file, you can modify the polyline vertex, which was generated by boundary.
Hope this helps you
Best regards.
Ing. Jaruzelsky Ugarte
Diseñador Vial
Mail: jaruugarte@hotmail.com
Tel:(505)5776-0506 – Claro
Message 12 of 21
jamieq
Thank you for the response and the files. However, addv.vlx appears to only have a routine to add vertices to polylines. I don't think this will help what I'm trying to accomplish.
Message 13 of 21
jaruugarte
when you load the app, this send a message, not only have command to add vertices, but have a command "delv", you can read in the command prompt.
Regards
Diseñador Vial
Message 14 of 21
Kent1Cooper
@jamieq wrote:
.... addv.vlx appears to only have a routine to add vertices to polylines. I don't think this will help ....
A similar routine to remove vertices should work, if the Hatch object is Associative, and is tied to the Polyline boundary.  Then if you change the Polyline [in any way, not only by removing vertices], the Hatch will follow.
Kent Cooper, AIA
Message 15 of 21
jamieq
Didn't see that. Thank you.
Message 16 of 21
john.uhden
@jamieq
In keeping with what @Kent1Cooper pointed out, I think the one-step solution would be one routine to...
  1. If there is no associative boundary, then recreate the boundary as associative.
  2. Include code like my VEDIT routine to add or remove vertices to/from the boundary.
  3. Remove the boundary if recreated.
Hmm, I could use this myself if I also added bulge modification.
Ya know, if you grip the hatch you can move, add, and remove vertices.  There's just no way to add or remove bulges.
John F. Uhden
Message 17 of 21
Kent1Cooper
If you pick the midpoint grip on a segment, you can use the Convert to [Arc or Line, depending] option.  But I think converting to an Arc segment is limited to dragging the midpoint -- I don't think you can specify a bulge factor, for instance, or a radius.
Kent Cooper, AIA
Message 18 of 21
john.uhden
@Kent1Cooper wrote "If you pick the midpoint grip on a segment, you can use the Convert to [Arc or Line, depending] option."
Thanks, Kent.  I think I had stumbled on that once, and of course forgot.
So the OP's solution is simply to grip the hatch and reconfigure its shape.
I will remember that now.
John F. Uhden
Message 19 of 21
Kent1Cooper
[If done manually, yes.  But see the Topic wording, and Messages 3 & 5.]
Kent Cooper, AIA
Message 20 of 21
Sea-Haven
is it quicker read hatch properties, then delete hatch, pick pline etc makes new "ASSOCITIVE" hatch with old properties, so edits work next time.
