Is it possible to get object reference to an object which is being referenced by an attribute?
ShricharanaB
ShricharanaB
I have an attribute in a block which references a point object in the block to get the z value in edit field. I know the tag of the attribute which will be same in all blocks. But the position of the point object may vary as it is dynamic. How can I get the reference to the point object so I can get it's current position?
There will be multiple points in the blocks and positions will be dynamic. I cannot get the value of the attribute itself because it will have only z value not the other two.
If it is possible to get the reference to this point object, will it still work if the attribute is hashed out ? (as in the values switch to ### because its lost it's reference or something. This seems to happen often.)
Hope I'm clear.
komondormrex
hi,
could you attach a target block?
