Is it possible to change the default File Explorer(Window) when printing/saving?
dustinbentzen
dustinbentzen
I am using AHK Scripts to open projects in Windows Explorer by entering a project number in a messagebox. This also works with all programms that use the default Windows Explorer window to save or export files.
Is it possible to change the ACAD save/export/print window to that of Windows?
Because the script wont work with the default AutoCAD window.
Best regards
Dustin
cadffm
No,
but i am sure that AHK can controle also the Autocad dialog, so you can expand your AHK "Script" to work with them.
But i am not a AHK user (years ago, for small helper functions only).
Sebastian
