Is An Xref Nested
Is An Xref Nested
Jason.Piercey
Advisor Advisor
Message 1 of 35
Is An Xref Nested
Jason.Piercey
I currently have a need for simply knowing if an xref is nested. Looking through my toolbox functions I have code for determining that based on user selection of a nested object (nentsel) but that doesn't fit my current requirements.  Hard to believe those functions were written some 23 years ago! Wow.
Anyway, it's been a long time since I've written much code so I'm a wee bit rusty.  Is testing for and/or using DXF code 102 enough for a nested determination?  Seems to work in my limited testing.
; determine if the specified block name is a nested xref
; Arguments:
; [document] vla-object, document object
; [name] string, xref name
; Return: T or nil
(defun nestedXref-p (document name / object)
  (and
    (setq object (vla-item (vla-get-blocks document) name))
    (= :vlax-true (vla-get-isxref object))
    (not (assoc 102 (entget (vlax-vla-object->ename object))))
Replies (34)
Message 2 of 35
paullimapa
Not sure about that but I’ve referred to this link for nested Xref testing
Paul Li
IT Specialist
@The Office
Message 3 of 35
Jason.Piercey
Thanks, I'll take a look at that link.
Message 4 of 35
komondormrex
i am pretty sure that link from message 2 suggests same method, but nevertheless why do not you try to check owner ID of xref in the first place?
Message 5 of 35
Jason.Piercey
I was looking at a dump (vlax-dump-object) of two different xrefs, one nested. I don't see how the OwnerID property helps in this case as the dump indicates that property is the same for both xrefs.
Message 6 of 35
komondormrex
well, that is very much peculiar, because if a block is nested, its owner has to be other that modelspace block for instance.
Message 7 of 35
Jason.Piercey
I've found my attempt at using DXF 102 is not reliable. So, scratch that.
Message 8 of 35
komondormrex
could you attach a sample with xref nested and not?
Message 9 of 35
Jason.Piercey
See attached for a simple example
Message 10 of 35
CADaSchtroumpf
I have this that explores Block or Xref insertions and returns information if these are nested or single.
(defun xplore (l / ent cnt msg)
  (princ
    (strcat "\nExplores \"" (cdr (assoc 2 l)) "\" the block that is "
      (if (ssget "_X" (list '(0 . "INSERT") (assoc 2 l)))
        "inserted into the drawing."
        "not inserted into the drawing."
  (setq ent (entget (cdr (assoc -2 l))) cnt 0)
  (cond
    ((eq (cdr (assoc 0 ent)) "INSERT")
      (princ (strcat "\n Contains the \"" (cdr (assoc 2 ent)) "\" block"))
      (while (setq ent (entnext (cdar ent)))
        (setq ent (entget ent))
        (if (eq (cdr (assoc 0 ent)) "INSERT")
          (progn
            (setq cnt (1+ cnt) msg "")
            (princ (strcat "\n Contains the \"" (cdr (assoc 2 ent)) "\" " (repeat cnt (setq msg (strcat "sub-" msg))) "block\n"))
(defun c:list_blk_children ( / flag n_blk l_blk dxf_ent dxf_blk dxf)
  (setq flag T)
  (while (setq n_blk (tblnext "BLOCK" flag))
    (setq l_blk (cons n_blk l_blk) flag nil)
  (cond
    (l_blk
      (foreach n l_blk
        (if (= (logand (cdr (assoc 70 n)) 4) 4)
          (progn
            (princ (strcat "\n\t\tXref found ---> \"" (cdr (assoc 1 n)) "\"\n"))
            (setq dxf_ent (entget (cdr (assoc 330 (entget (tblobjname "BLOCK" (cdr (assoc 2 n))))))))
            (if (setq dxf_blk (cdr (member '(102 . "{BLKREFS") dxf_ent)))
              (while (not (equal (car dxf_blk) '(102 . "}")))
                (setq dxf (entget (cdar dxf_blk)))
                (cond
                  ((eq (cdr (assoc 0 dxf)) "INSERT")
                    (princ (strcat "\n\t\twhich is a nested \"XREF\" named: \"" (cdr (assoc 2 dxf)) "\""))
                  ((eq (cdr (assoc 0 dxf)) "BLOCK_RECORD")
                    (princ (strcat "\n\t\twhich is a simple \"XREF\" named: \"" (cdr (assoc 2 dxf)) "\""))
                (setq dxf_blk (cdr dxf_blk))
          (if (/= (logand (cdr (assoc 70 n)) 16) 16)
            (xplore n)
        (textpage)
    (T
      (princ "\nNo block defined!")
  (prin1)
Message 11 of 35
paullimapa
what is the "l" argument to feed to function xplore?
Paul Li
IT Specialist
@The Office
Message 12 of 35
CADaSchtroumpf
Is for exemple (xplore (tblsearch "BLOCK" "your_name block"))
In my code, I search all block with (tblnext "BLOCK") where I construct a list and (foreach el  list  I use xplore  for each element
Message 13 of 35
paullimapa
not working for me...with MASTER.dwg opened, I load xplore and enter:
(xplore (tblsearch "BLOCK" "your_name block")) in my case it's XREF_B or XREF_A I get:
Paul Li
IT Specialist
@The Office
Message 14 of 35
paullimapa
Oh, and I just ran the list_blk_children command and I got the reverse answer:
Paul Li
IT Specialist
@The Office
Message 15 of 35
CADaSchtroumpf
For me work's in MASTER.dwg
Commande: LIST_BLK_CHILDREN
Xref found ---> "C:\Autodesk\XREF_B.dwg"
Xref found ---> "C:\Autodesk\XREF_A.dwg"
which is a nested "XREF" named: "XREF_A"
which is a simple "XREF" named: "XREF_B"
(xplore) is for only ""INSERT" -> block not XRef
Block can be have other block nested
Exemple with this dwg
Message 16 of 35
paullimapa
ok, but should it not show that:
XREF_A" is the simple xref
"XREF_B" is the nested one instead of showing it like this?
Paul Li
IT Specialist
@The Office
Message 17 of 35
komondormrex
truly it is the same for block-xref definition and points to blocks collection. this may differ for block references. but in your example you have only one xref as block reference and it is 'not nested'. at the same time references palette shows two xrefs of which the second is 'nested' and it nested in 'not nested' xref. in that particular scenario nested xref may be found by nil ssgetting block reference named 'nested'. if ssget gives nil result, but block definition of 'nested' block is in database then it is obviously nested.
Message 18 of 35
ronjonp
@komondormrex About the SSGET method read HERE from the link above.
Message 19 of 35
komondormrex
well, thank you. it is function btw)
Message 20 of 35
ronjonp
Yes, I know SSGET is a function. I was referring to your method🤓
See below in green .. that was what I was referring to:
