Invoke contextual ribbon when selecting a specific block
Shay.Gaghe
Shay.Gaghe
Hi
When I click a block with a certain prefix in it's name I want to invoke a contextual ribbon.
How it can be done?
Tx.  S
Using Autocad 2018, Autocad Architecture.
Please accept as solution if i solved your problem
jduframe
this is an example I have for dimension linear toolbar button
^C^C(command "+RIBBON" "ACAD.ID_TabAnnotate");_dimlinear
jduframe
under CUI editor you look under ribbons for the ID and replace (underlined) with ID wanted
and the last part is the command invoked
Shay.Gaghe
U call the annotate tab Ben ever a dim is selected?  But how I can call a  costume tab only when a specific block is selected?
jduframe
not sure on that, I only know how to have ribbon change when toolbar button is selected, unless you want to make a button that inserts the block and calls the ribbon all in one
jduframe
^C^C(command "+RIBBON" "ACAD.ID_TabAnnotate");_insert;DetB;\;;;;;^C^C
I believe it would be similiar to this, with ribbon name replaced and which ever you name you block
Shay.Gaghe
I'll give it a try. Tx
