Invert Selection Set
Kyudos
Advisor Advisor
Message 1 of 11
Kyudos
I'm looking for some LISP to invert the AutoCAD selection - deselect all selected items, and select all those not selected (forming a new selection set). Ideally, it would only work on the current selection (the PICKFIRST selection).
I found this on another board:
(defun c:invss (/ ss ss2 n)
  (setq	ss  (ssget)
    ss2 (ssget "_x")
  (if ss
    (progn
      (repeat (setq n (sslength ss))
        (ssdel (ssname ss (setq n (1- n))) ss2)
      (if ss2
        (sssetfirst nil ss2)
But it doesn't seem to work properly. Knowing nothing about LISP I haven't a clue why.
Can anyone help?
Cheers:)
Replies (10)
Message 2 of 11
marko_ribar
For me it works, although I did some modifications...
(defun c:invss ( / ss ss2 n )
  (setq	ss (ssget)
    ss2 (ssget "_X")
  (if ss
  (if ss2
  (princ)
M.R.
Marko Ribar, d.i.a. (graduated engineer of architecture)
Message 3 of 11
Kent1Cooper
Here's my take on it -- very lightly tested, but it works in noun-verb or verb-noun mode [i.e. if you have anything pre-selected when you enter the command, it selects/grips/highlights everything except that pre-selection, or if you don't, it asks you to select objects, then selects/grips/highlights everything except those].
(defun C:SAB (/ ss); = Select All But
  (setq ss
    (cond
      ((ssget "_I")); preselection, if any
      ((ssget)); User selection if no pre-selection
    ); cond
  ); setq
  (sssetfirst nil); clear preselection, if any, to not to in at Select command
  (command "_.select" "_all" "_remove" ss "")
  (sssetfirst nil (ssget "_P")); select/grip/highlight
); defun
Add an appropriate prompt if desired, and/or put the final selection into a variable if needed, etc.  If you really want it to work only with a pre-selection, isolate that out of the (cond) function and dump the User-selection part.
It has a slightly different effect than the versions using (ssget "_X"), since those will find everything in the drawing, even in other than the current space, whereas this will work only with things in the current space.  Depending on what you plan to do with the result, that may be preferable, anyway.
EDIT:  In fact, if you want it to work only with pre-selection, there isn't even any need for the 'ss' variable:
(defun C:SAB ()
  (if (ssget "_I")
    (progn ; then
      (sssetfirst nil)
      (command "_.select" "_all" "_remove" (ssget "_P") "")
    (prompt "\nRequires pre-selection."); else
  ); if
); defun
Kent Cooper, AIA
Message 4 of 11
Kyudos
Perfect thank you
Message 5 of 11
franc_as
Hi
Is it possible to modify this routine, so it will consider only selected layer (To invert selection only within layer on which selected object(s) is placed)?
Regards
Message 6 of 11
Kent1Cooper
@franc_as wrote:
.... Is it possible to modify this routine...?
[Which one?]
Kent Cooper, AIA
Message 7 of 11
franc_as
(defun C:SAB ()
(if (ssget "_I")
(progn ; then
(sssetfirst nil)
); if
); defun
Message 8 of 11
Kent1Cooper
This seems to do that [minimally tested]:
(defun C:SABL (/ ss n lay laylist laystr)
; = Select All But, on pre-selected objects' Layer(s) only
  (if (setq ss (ssget "_I")); pre-selection
    (progn ; then
      (sssetfirst nil); clear selection
      (repeat (setq n (sslength ss)); Layer(s) of selected object(s)
        (setq lay (cdr (assoc 8 (entget (ssname ss (setq n (1- n)))))))
        (if (not (member lay laylist))
          (setq
            laylist (cons lay laylist); for checking if already present
            laystr (strcat (cond (laystr) ("")) lay ","); for (ssget)
          ); setq
        ); if
      ); repeat
      (command "_.select" (ssget "_X" (list (cons 8 laystr))) "_remove" ss "")
    ); progn
  ); if
  (prin1)
); defun
Kent Cooper, AIA
Message 9 of 11
franc_as
Thank you Kent...it works fine for me
Message 10 of 11
rmc9WR3X
To invert the selection, a command that every design software has had for decades now, I must code the command myself. No thank you, Autodesk. I am a designer attempting a simple design operation.
Message 11 of 11
john.uhden
@rmc9WR3X ,
AutoCAD has a litany of shortcomings.
That's why they pay nothing to have brilliant volunteers help provide solutions. 😞
John F. Uhden
