Let's say that obj1 is the vla-object representing the xref and that obj2 is the vla-object representing a polyline that intersects with the xref one or more times.
The intersections can be obtained using:
(setq ints (vlax-invoke obj1 'intersectwith obj2 0))
Of course the result is what we call a flat list, not a list of separate points, but a list like
(x1 y1 z1 x2 y2 z2 ... xn yn zn)
I use the following function to convert the flat list into a list of 3D points:
;; Function to group a list of items into a list of
;; multiple lists, each of length N, e.g.
;; '(A B C D E F G H I) -> '((A B C)(D E F)(G H I))
(defun @group (lst n / item new)
(foreach element (reverse lst)
(setq item (cons element item))
(if (= (length item) n)
(setq new (cons item new) item nil)
new
The programmer must know in advance whether the flat list is 2D or 3D.
If the flat list is 3D then (setq ints (@group ints 3))
If the flat list is 2D then (setq ints (@group ints 2))
You may be surprised with the results because the intersectwith method treats things like inserts and mtext as though they were a rectangular box, just the same as the getboundingbox method. So there are likely to be fewer intersections returned than what you deduce visually. I have not yet found a way using Lisp to retrieve all the apparent intersections. I suppose it might be done by temporarily exploding the insert or mtext and trying to interpret the intersection points of each component, but I have successfully avoided such an undertaking for lack of need. It's too bad that Autodesk doesn't provide us a getboundingpolygon method.
