intersecting lines/polyline
Hi guys,
please see the attached files.
I have a lot of lines or rectangles that are intersecting.
I want it to be only the outlines of these lines.
The intersect command does the exact opposite 😞
Using autocad 2013 and up.
Thank you
rkmcswain
Convert them to regions and then use UNION?
If you have an AEC product, there is a command called LINEWORKSHRINKWRAP that will do it in one step.
R.K. McSwain     | CADpanacea | on twitter
hmsilva
Try Lee Mac's Outline Objects...
Hope this helps,
Henrique
Kent1Cooper
In some overlay programs, there's a LINEWORKSHRINKWRAP command [I learned of it here].  If you don't have that, do a Search on this board for "shrinkwrap" and you'll find a number of threads about the same idea.
Kent Cooper, AIA
