Install plugin on a specific profile behalf
Shay.Gaghe
Shay.Gaghe
hi
im using few profiles for my disciplines. now when I want to install a plugin I'm confused about how to install it so it will be active only in a specific profile of my choice?
S
Using Autocad 2018, Autocad Architecture.
Please accept as solution if i solved your problem
cadffm
What do you mean with " a plugin" in detail?
Different types of "plug In", different ways to go.
Sebastian
Moshe-A
@Shay.Gaghe  hi,
if the 'plugin' is a lisp file (not an application that installed by some setup program)  then you can add lisp files to Appload Startup Suite for specific profile.
HKEY_CURRENT_USER\Software\Autodesk\AutoCAD\RXX.0\ACAD-XXXX:XXX\Profiles\<<YourProfileNamed>>\Dialogs\Appload\Startup
Moshe
Shay.Gaghe
my plugin is made of lisps using external files like dwg,excel,txt,partial cuix,workspace and desktop shortcut that load that profile.
Shay.Gaghe
its a program
scot-65
Will checking the variable CPROFILE suit your needs?
I am assuming your applications are (pre)loading thru a third-party
interface such as acaddoc.lsp and/or MyMenu.mnl.
(if (= (strcase (getvar 'CPROFILE)) "PROFILE-1")
(progn
(defun c:ABC () (if (load "program-ABC" nil) (c:ABC)))
(defun c:DEF () (if (load "program-DEF" nil) (c:DEF)))
etc.
);progn
);if
Scot-65
A gift of extraordinary Common Sense does not require an Acronym Suffix to be added to my given name.
