InsertLoopAt method of a Hatch object
tcorey
Mentor Mentor
tcorey
Do you know how to use it?
Tim Corey
MicroCAD Training and Consulting, Inc.
Redding, CA
Autodesk Platinum Reseller
New knowledge is the most valuable commodity on earth. -- Kurt Vonnegut
CodeDing
@tcorey ,
Have you checked the documentation?
https://help.autodesk.com/view/OARX/2020/ENU/?guid=GUID-E35E3387-14E8-433D-B6A6-82E034A11BEE
Do you have a specific question?
Best,
~DD
john.uhden
I think the help shows how to pretty well using ActiveX.
I think I tried it once for kicks and it worked, but I didn't save any code.
Anyway, the HATCHEDIT command makes it easy anyway.
But today I was altering geometry to get proposed impervious lower than existing.
I had all the loops on the same layer "IMPERV-PL" so I just used my GripLayer and the -HATCH command to rebuild the hatch and then get its area.  It wasn't painful at all except that I learned that if an outer loop touches itself, the area property is not applicable or available.  So I just cheated and stretched a few points away from others.  The reviewers and even my boss wouldn't be able to see anything awry over 19+ crooked acres, even if they had AutoCAD.
John F. Uhden
