Inserting UniformScale Block problem
WF.Con
WF.Con
Hi all, and thanks for reading/helping in advance
I've set all my blocks to UniformScale: Yes
However I can't seem to modify my old lisps to insert them correctly.
In the form below, it somehow scales it 10x.
I get to pick the insertion point, then it scales 10x and then I get to pick rotation, and then explodes the block.
i'm pretty sure it has something to do with the  pauze 1 pauze pauze setting
(defun C:FP ( / PHASE_naam choice ss )
  (initget 7 "H V")
  (setq choice (getkword "PHASE <Horizontal, Vertical>: "))
  ;; Set block name based on choice
  (setq PHASE_naam
    (cond
      ((= choice "H") "PHASE_Horizontal")
      ((= choice "V") "PHASE_Vertical")
  (command "insert" PHASE_naam pause 1 pause pause)
  ;; Select the last inserted block for explosion
  (setq ss (ssget "L"))  ;; Get the last created object
  (command "explode" ss) ;; Explode the selected block
ВeekeeCZ
Blocks are in mm, what units is your drawing in?
The code adjusted a little.
(defun C:FP ( / choice )
  (initget "Horizontal Vertical")
  (if (setq choice (getkword "PHASE [Horizontal/Vertical]: "))
    (command "insert" (strcat "PHASE_" choice) "_s" 1 pause pause
	     "explode" "last"))
  (princ)
WF.Con
Your code works perfectly...
The blocks were in mm, so was the combined block.
Gues the code got a bit to complicated, thanks for your time!
Been wrestling with this one all day
ВeekeeCZ
When inserting a block, it's better to call the hidden option (of scale) right away, rather than wait for whether it comes and where. This way, it does not differentiate uniform-scaled blocks from non-uniform ones.
(command "_.insert" "blockname" "_scale" 1 ...do the rest....)
WF.Con
Thanks for the clarification, definitely going to update my other lisps like that.
Updated all our blocks to "scale uniformly" because I noticed dataextraction always gives an error on misaligned scales.
