Dear Members!
I wrote a LISP to insert specified blocks to coords of COGO points with specified layers (it's not a working way to change the point style or label, sometimes I need to move the block separately from the point, or freeze the point but not the block). It works nice, but there are some problems I encountered when I tried to "improve" the code:
- it places the blocks without problem, but if I select more than 1 COGO point, it writes an error in the command line after inserting the last block:
"bad argument type: lselsetp #<VLA-OBJECT IAcadSelectionSet 000000005cc085d8>"
I looked it up, and it means the selection set is empty, but I don't understand what does it really mean. Any way to get rid of this error message?
- I tried to make it write the total number of inserted blocks in the command line after inserting the last block, but I only get the "lselsetp" error (but with different numbers at the end of it).
One of the methods I tried:
(setq blks (ssget "X" '((0 . "INSERT"))) blkcount (sslength blks)) (princ blkcount)
- my company have 576 layers that have a specified block to insert, so I copied the "(if (= player "...")..." section 576 times. Is there any way to make it simpler?
- my company uses a lot of blocks stored in a seperate DWG. Is there a way of selecting and inserting only the needed blocks from it? Currently the LISP copies and inserts all of the block definitions into the actual drawing and it takes time (and makes the size of the file unnecessarily large).
- is there a way to make it check if there is already a block on a selected COGO point? Maybe display the "Do you want to replace existing blocks?" question in the command line after starting the command with the options "Yes/No"?
My code:
;====DISPLAY ERROR (defun *error* ( msg ) (if (not (member msg '("Function cancelled" "quit / exit abort"))) (princ (strcat "\nError: " msg)) ) (princ) ) ;====PROGRAM (defun c:bf1 (/ pnts i pnt1 x pnt eastng northng elev player blks blkcount) (vl-load-com) (setq oldsnap (getvar "osmode") ;saves the old settings oldblipmode (getvar "blipmode") oldlayer (getvar "CLAYER")) (setvar "osmode" 0) ;turn off all objact snap (setvar "blipmode" 0) (command "_.insert" "blocks.dwg")(command) ;insert drawing with all the block definition, drawing must be in ACAD support path! (if (setq pnts (ssget '((0 . "AECC_COGO_POINT")))) ;select COGO points (progn (setq i 0) (repeat (sslength pnts) ;repeating to all selected COGO points setq pnt1 (vlax-ename->vla-object (ssname pnts i)) (progn (vlax-for x (setq pnts (vla-get-activeselectionset (vla-get-activedocument (vlax-get-acad-object)))) (setq pnt (vlax-get x 'number) eastng (vlax-get x 'easting) northng (vlax-get x 'northing) elev (vlax-get x 'elevation) pfolia (vlax-get x 'layer) ) ;end of setq (if (= player "Layer1") (command "_.-layer" "_set" "Layer_Block_1" "" "_.insert" "Block1" (list eastng northng elev) "" "" "" ) ) (if (= player "Layer2") (command "_.-layer" "_set" "Layer_Block_2" "" "_.insert" "Block2" (list eastng northng elev) "" "" "" ) )
(setq i (1+ i))
) ;end of vlax-for
) ;end of progn in repeat
) ;end of repeat
) ;end of progn in if
(princ "No point selected!")
) ;end of if
(setvar "osmode" oldsnap) ;restore old settings
(setvar "blipmode" oldblipmode)
(setvar "CLAYER" oldlayer)
(princ)
) ;end of defun
I hope you can help me with these, I'd be very happy 🙂
Thanks for considering my request.
Daniel
