Insert specific block at a POSITION parameter in another block
cksE6SE5
cksE6SE5
Hi all!
I need a LISP command to automatically insert a "Position number" block at a point called "POSDATA" in my conveyor block. I tried using the following LISP, but it just doesn't work:
(defun c:POS (/  valid_blocks f ss i e data dpp len)
;;(setq valid_blocks '("CONV-480-B190""));;
(setq f (lambda (p) (vlax-get e p)))
(if
      (setq ss (ssget '((0 . "INSERT")(2 . "`*U*,CONV-*"))))
  	(repeat (setq i (sslength ss))
          (setq e (vlax-ename->vla-object (ssname ss (Setq i (1- i)))))
          (setq data (mapcar 'f  '("Insertionpoint" "Rotation" "EffectiveName" "XScaleFactor")))
          (if (and
                ;;(member (caddr data) valid_blocks)
		(vl-string-search "CONV-" (caddr data))
                (setq dpp (mapcar '(lambda (e) (mapcar 'f
                                      '("PropertyName" "Value" )))
                                    (vlax-invoke e 'GetDynamicBlockProperties)))
                (> (setq len (cadr (Assoc "Posdata" dpp))) 0)
		(vlax-invoke
		  (vlax-get (vla-get-ActiveLayout
		              (vla-get-activedocument
		                (vlax-get-acad-object)
		            'Block
		  'InsertBlock
		  (polar (car data)
                         (+ (if (minusp (last data)) pi 0.0) (Cadr data))
                         len)
		  "POSITION2"	;; block needs to be in drawing to execute command
		  1 1 1 0) ;; <-- block rotation 0
  (princ)
I don't have any experience in coding at all, so I don't know what to do other than replacing names and values in the code. Just for info, the conveyor blocks might vary in name, but they all start with "CONV-", eg.:
CONV-480-B180
CONV-580-B380
CONV-680-B90
and so on...
Attached example drawing with the conveyor block and the position block, and a description of what it is supposed to look like.
If any questions, I'll be glad to elaborate 🙂 thanks in advance
ВeekeeCZ
Seems ok this way.
(defun c:POS (/  valid_blocks f ss i e data dpp lenx leny)
  (if
      (setq data (mapcar 'f  '("Insertionpoint" "Rotation" "EffectiveName" "XScaleFactor" "YScaleFactor")))
      (if (and
	    (setq lenx (cadr (Assoc "POSDATA X" dpp)))
	    (setq leny (cadr (Assoc "POSDATA Y" dpp)))
	(vlax-invoke
		    'Block
	  'InsertBlock
	  (polar (polar (car data)
			(+ (if (minusp (cadddr data)) pi 0.0) (Cadr data))
			lenx)
		 (+ (if (minusp (last data)) pi 0.0) (+ (* 0.5 pi) (Cadr data)))
		 leny)
  (princ)
cksE6SE5
Seems to work as intended - thank you very much 🙂
cksE6SE5
I noticed one minor issue (at least I hope it's minor). When I Rotate3D or 3DR one of my conveyors, the position-block doesn't adhere correctly to the snap point, but rather places itself several meters out in the open... Any ways to fix this?Captureconv.JPG
