Hello arshadmirza786.
Here I have one.
It's works with both DWG and DXF and is menu based.
For DXF files you do have to make sure the UNITS are the same as the master drawing.
In the first menu just drop the directory with the files copied from your file-browser.
In the second menu you can choose the files you want to insert.
You can use the Ctrl en Shift keys to add multiple files at ones.
(defun c:insert-drawings ( / dir lst f count)
(setq count 0)
(setq dir (RvdW:Inputbox_1 "Insert directory"))
(setq lst (LM:getfiles "Select Drawings" dir "dwg,dxf"))
(RvdW:aup-start (length lst))
(foreach f lst ; (setq f (nth 1 lst))
(RvdW:insert-file (strcat (vl-filename-directory f) "\\") (strcat (vl-filename-base f) (vl-filename-extension f)))
(RvdW:aup)
(setq count (+ count 1))
) ; foreach
(RvdW:aup-stop)
(vl-cmdf "zoom" "E")
(alert (strcat "We are done.\n" (rtos count) " drawings have been insert."))
;___________________________________________________________________________________________________________
(defun RvdW:Inputbox_1 ( txt / dcl_01 name )
(setq dcl_01 (load_dialog (strcat (getvar 'TEMPPREFIX) "dcl-menu.dcl")))
(new_dialog "Inputbox_1" dcl_01)
(set_tile "txt1" txt)
(mode_tile "name" 2)
(action_tile "name" "(setq name $value)")
(action_tile "accept" "(done_dialog)")
(start_dialog)
(unload_dialog dcl_01)
name
(defun PasswordDialogWrite (/ z)
(setq z (open (strcat (getvar 'TEMPPREFIX) "dcl-menu.dcl") "w"))
(write-line "Inputbox_1 :dialog{label=\"Input box 1\";:text{key=\"txt1\";fixed_width=true;width=50;}" z)
(write-line ":edit_box{edit_limit=256;label=\"\";key=\"name\";}" z)
(write-line ":button{key=\"accept\";label=\"OK\";is_default=true;fixed_width=true;alignment=centered;}" z)
(write-line "}" z)
(close z)
(defun RvdW:aup-start (c)
(setq acet-ui-progress-counter nil)
(acet-ui-progress "Working:" c)
(defun RvdW:aup ()
(if (= acet-ui-progress-counter nil)
(acet-ui-progress (setq acet-ui-progress-counter 1))
(acet-ui-progress (setq acet-ui-progress-counter (+ acet-ui-progress-counter 1)))
(defun RvdW:aup-stop ()
(acet-ui-progress)
;;; controle of een dwg tekening niet open staat
;;; d = dir
;;; f = file
;;; if you don't have a sepatate dir and filename then use;
;;; d = nil
;;; f = value
(defun RvdW:insert-file (d f)
(if (= d nil)
(setq fl f)
(setq fl (strcat d f))
(if (/= (findfile (strcat (substr fl 1 (- (strlen fl) 4)) ".dwl")) nil)
(progn
(if (=
(ACET-UI-MESSAGE (strcat "drawing " (vl-filename-base fl) " is open\blocked.\nDo you want to continue?") "YES/NO Dialog"
(+ Acet:YESNO) ; ja=6 nee=7
7)
(quit)
) ; if
) ; progn
(RvdW:insert-drawings fl)
) ; if
) ; defun
(defun RvdW:insert-drawings ( fl / dbx acver doc l obj )
(setq dbx
(vla-GetInterfaceObject (vlax-get-acad-object)
(if
(< (setq acver (atoi (getvar "ACADVER"))) 16)
"ObjectDBX.AxDbDocument"
(strcat "ObjectDBX.AxDbDocument." (itoa acver))
(cond ((= (vl-filename-extension fl) ".dxf")
(command "_.-insert" fl '(0. 0. 0.) """""")
(command "_.explode" (entlast))
((= (vl-filename-extension fl) ".dwg")
(vla-open dbx fl :vlax-true)
(vlax-for obj (vla-get-modelspace (cond (doc) (dbx)))
(setq l (cons obj l))
(if l
(vlax-invoke (cond (doc) (dbx)) 'copyobjects l (vla-get-modelspace (vla-get-activedocument (vlax-get-acad-object))))
(vlax-release-object dbx)
(T)
;;------------------------=={ Get Files Dialog }==----------------------;;
;; An analog of the 'getfiled' function for multiple file selection. ;;
;; Author: Lee Mac, Copyright © 2012 - www.lee-mac.com ;;
;; Arguments: ;;
;; msg - [str/nil] Dialog box label; 'Select Files' if nil or "". ;;
;; def - [str/nil] Default directory; dwgprefix if nil or "". ;;
;; ext - [str/nil] File extension filter (e.g. "dwg;lsp"); "*" if nil ;;
;; Returns: List of selected files, else nil ;;
;; Version 1.6 - 2016-03-21 ;;
(defun LM:getfiles ( msg def ext / *error* dch dcl des dir dirdata lst rtn )
(defun *error* ( msg )
(if (= 'file (type des))
(close des)
(if (and (= 'int (type dch)) (< 0 dch))
(unload_dialog dch)
(if (and (= 'str (type dcl)) (findfile dcl))
(vl-file-delete dcl)
(if (and msg (not (wcmatch (strcase msg t) "*break,*cancel*,*exit*")))
(princ (strcat "\nError: " msg))
(princ)
(if
(and
(setq dcl (vl-filename-mktemp nil nil ".dcl"))
(setq des (open dcl "w"))
(progn
(foreach x
"lst : list_box"
" width = 40.0;"
" height = 20.0;"
" fixed_width = true;"
" fixed_height = true;"
" alignment = centered;"
" multiple_select = true;"
"but : button"
" width = 20.0;"
" height = 1.8;"
"getfiles : dialog"
" key = \"title\"; spacer;"
" : row"
" : edit_box { key = \"dir\"; label = \"Folder:\"; }"
" : button"
" key = \"brw\";"
" label = \"Browse\";"
" spacer;"
" : row"
" : column"
" : lst { key = \"box1\"; }"
" : but { key = \"add\" ; label = \"Add Files\"; }"
" : column {"
" : lst { key = \"box2\"; }"
" : but { key = \"del\" ; label = \"Remove Files\"; }"
" spacer; ok_cancel;"
(write-line x des)
(setq des (close des))
(< 0 (setq dch (load_dialog dcl)))
(new_dialog "getfiles" dch)
(progn
(setq ext (if (= 'str (type ext)) (LM:getfiles:str->lst (strcase ext) ";") '("*")))
(set_tile "title" (if (member msg '(nil "")) "Select Files" msg))
(set_tile "dir"
(setq dir
(LM:getfiles:fixdir
(if (or (member def '(nil "")) (not (vl-file-directory-p (LM:getfiles:fixdir def))))
(getvar 'dwgprefix)
def
(setq lst (LM:getfiles:updatefilelist dir ext nil))
(mode_tile "add" 1)
(mode_tile "del" 1)
(action_tile "brw"
(vl-prin1-to-string
'(if (setq tmp (LM:getfiles:browseforfolder "" nil 512))
(setq lst (LM:getfiles:updatefilelist (set_tile "dir" (setq dir tmp)) ext rtn)
rtn (LM:getfiles:updateselected dir rtn)
(action_tile "dir"
(vl-prin1-to-string
'(if (= 1 $reason)
(setq lst (LM:getfiles:updatefilelist (set_tile "dir" (setq dir (LM:getfiles:fixdir $value))) ext rtn)
(action_tile "box1"
(vl-prin1-to-string
(lambda ( / itm tmp )
(if (setq itm (mapcar '(lambda ( n ) (nth n lst)) (read (strcat "(" $value ")"))))
(if (= 4 $reason)
(cond
( (equal '("..") itm)
(setq lst (LM:getfiles:updatefilelist (set_tile "dir" (setq dir (LM:getfiles:updir dir))) ext rtn)
( (vl-file-directory-p (setq tmp (LM:getfiles:checkredirect (strcat dir "\\" (car itm)))))
( (setq rtn (LM:getfiles:sort (append rtn (mapcar '(lambda ( x ) (strcat dir "\\" x)) itm)))
lst (LM:getfiles:updatefilelist dir ext rtn)
(if (vl-every '(lambda ( x ) (vl-file-directory-p (strcat dir "\\" x))) itm)
(mode_tile "add" 1)
(mode_tile "add" 0)
(action_tile "box2"
(vl-prin1-to-string
(lambda ( / itm )
(if (setq itm (mapcar '(lambda ( n ) (nth n rtn)) (read (strcat "(" $value ")"))))
(if (= 4 $reason)
(setq rtn (LM:getfiles:updateselected dir (vl-remove (car itm) rtn))
(mode_tile "del" 0)
(action_tile "add"
(vl-prin1-to-string
(lambda ( / itm )
(if
(setq itm
(vl-remove-if 'vl-file-directory-p
(mapcar '(lambda ( n ) (nth n lst)) (read (strcat "(" (get_tile "box1") ")")))
(mode_tile "add" 1)
(mode_tile "del" 1)
(action_tile "del"
(vl-prin1-to-string
(lambda ( / itm )
(if (setq itm (read (strcat "(" (get_tile "box2") ")")))
(setq rtn (LM:getfiles:updateselected dir (LM:getfiles:removeitems itm rtn))
(mode_tile "add" 1)
(mode_tile "del" 1)
(if (zerop (start_dialog))
(setq rtn nil)
(*error* nil)
rtn
(defun LM:getfiles:listbox ( key lst )
(start_list key)
(foreach x lst (add_list x))
(end_list)
lst
(defun LM:getfiles:listfiles ( dir ext lst )
(vl-remove-if '(lambda ( x ) (member (strcat dir "\\" x) lst))
(cond
( (cdr (assoc dir dirdata)))
( (cdar
(setq dirdata
(cons
(cons dir
(append
(LM:getfiles:sortlist (vl-remove "." (vl-directory-files dir nil -1)))
(LM:getfiles:sort
(if (member ext '(("") ("*")))
(vl-directory-files dir nil 1)
(vl-remove-if-not
(function
(lambda ( x / e )
(and
(setq e (vl-filename-extension x))
(setq e (strcase (substr e 2)))
(vl-some '(lambda ( w ) (wcmatch e w)) ext)
dirdata
(defun LM:getfiles:checkredirect ( dir / itm pos )
(cond
( (vl-directory-files dir) dir)
( (and
(= (strcase (getenv "UserProfile"))
(strcase (substr dir 1 (setq pos (vl-string-position 92 dir nil t))))
(setq itm
(cdr
(assoc (substr (strcase dir t) (+ pos 2))
("my documents" . "Documents")
("my pictures" . "Pictures")
("my videos" . "Videos")
("my music" . "Music")
(vl-file-directory-p (setq itm (strcat (substr dir 1 pos) "\\" itm)))
itm
( dir )
(defun LM:getfiles:sort ( lst )
(apply 'append
(mapcar 'LM:getfiles:sortlist
(vl-sort
(LM:getfiles:groupbyfunction lst
(lambda ( a b / x y )
(and
(setq x (vl-filename-extension a))
(setq y (vl-filename-extension b))
(= (strcase x) (strcase y))
(function
(and
(setq x (vl-filename-extension (car a)))
(setq y (vl-filename-extension (car b)))
(< (strcase x) (strcase y))
(defun LM:getfiles:sortlist ( lst )
(mapcar (function (lambda ( n ) (nth n lst)))
(vl-sort-i (mapcar 'LM:getfiles:splitstring lst)
(function
(while
(and
(setq x (car a))
(setq y (car b))
(= x y)
(setq a (cdr a)
b (cdr b)
(cond
( (null x) b)
( (null y) nil)
( (and (numberp x) (numberp y)) (< x y))
( (numberp x))
( (numberp y) nil)
( (< x y))
(defun LM:getfiles:groupbyfunction ( lst fun / tmp1 tmp2 x1 )
(if (setq x1 (car lst))
(progn
(foreach x2 (cdr lst)
(if (fun x1 x2)
(setq tmp1 (cons x2 tmp1))
(setq tmp2 (cons x2 tmp2))
(cons (cons x1 (reverse tmp1)) (LM:getfiles:groupbyfunction (reverse tmp2) fun))
(defun LM:getfiles:splitstring ( str )
(lambda ( l )
(read
(strcat "("
(vl-list->string
(apply 'append
(mapcar
(function
(lambda ( a b c )
(cond
( (member b '(45 46 92))
(list 32)
( (< 47 b 58)
(list b)
( (list 32 34 b 34 32))
(cons nil l) l (append (cdr l) '(( )))
(vl-string->list (strcase str))
(defun LM:getfiles:browseforfolder ( msg dir flg / err fld pth shl slf )
(setq err
(vl-catch-all-apply
(function
(lambda ( / app hwd )
(if (setq app (vlax-get-acad-object)
shl (vla-getinterfaceobject app "shell.application")
hwd (vl-catch-all-apply 'vla-get-hwnd (list app))
fld (vlax-invoke-method shl 'browseforfolder (if (vl-catch-all-error-p hwd) 0 hwd) msg flg dir)
(setq slf (vlax-get-property fld 'self)
pth (LM:getfiles:fixdir (vlax-get-property slf 'path))
(if slf (vlax-release-object slf))
(if fld (vlax-release-object fld))
(if shl (vlax-release-object shl))
(if (vl-catch-all-error-p err)
(prompt (vl-catch-all-error-message err))
pth
(defun LM:getfiles:full->relative ( dir path / p q )
(setq dir (vl-string-right-trim "\\" dir))
(cond
( (and
(setq p (vl-string-position 58 dir))
(setq q (vl-string-position 58 path))
(/= (strcase (substr dir 1 p)) (strcase (substr path 1 q)))
path
( (and
(setq p (vl-string-position 92 dir))
(setq q (vl-string-position 92 path))
(= (strcase (substr dir 1 p)) (strcase (substr path 1 q)))
(LM:getfiles:full->relative (substr dir (+ 2 p)) (substr path (+ 2 q)))
( (and
(= (strcase dir) (strcase (substr path 1 q)))
(strcat ".\\" (substr path (+ 2 q)))
( (= "" dir)
path
( (setq p (vl-string-position 92 dir))
(LM:getfiles:full->relative (substr dir (+ 2 p)) (strcat "..\\" path))
( (LM:getfiles:full->relative "" (strcat "..\\" path)))
(defun LM:getfiles:str->lst ( str del / pos )
(if (setq pos (vl-string-search del str))
(cons (substr str 1 pos) (LM:getfiles:str->lst (substr str (+ pos 1 (strlen del))) del))
(list str)
(defun LM:getfiles:updatefilelist ( dir ext lst )
(LM:getfiles:listbox "box1" (LM:getfiles:listfiles dir ext lst))
(defun LM:getfiles:updateselected ( dir lst )
(LM:getfiles:listbox "box2" (mapcar '(lambda ( x ) (LM:getfiles:full->relative dir x)) lst))
lst
(defun LM:getfiles:updir ( dir )
(substr dir 1 (vl-string-position 92 dir nil t))
(defun LM:getfiles:fixdir ( dir )
(vl-string-right-trim "\\" (vl-string-translate "/" "\\" dir))
(defun LM:getfiles:removeitems ( itm lst / idx )
(setq idx -1)
(vl-remove-if '(lambda ( x ) (member (setq idx (1+ idx)) itm)) lst)
; ____________________________ end LM:getfiles ____________________________
