insert lisp formula on existing table drawing. how to inser formula on row 3 or 4!?
10:41 AM
;Insert table
(defun insert_table (lst pct / tab row col ht i n space)
(setq space (vlax-get acDoc (if (= 1 (getvar 'cvport)) 'PaperSpace 'ModelSpace))
ht (/ 2.5 (cond ((getvar 'cannoscalevalue)) (1.0)))
pct (trans pct 1 0)
n (trans '(1 0 0) 1 0 T)
;4 linhas em (+ 4 (length lst)
tab (setq tab (vla-addtable space (vlax-3d-point pct) (+ 4 (length lst)) (length (car lst)) (* 2.5 ht) ht))
(vlax-put tab 'direction n)
(mapcar
(function
(lambda (rowType)
(vla-SetTextStyle tab rowType (getvar 'textstyle))
(vla-SetTextHeight tab rowType ht)
'(2 4 1)
(vla-put-HorzCellMargin tab (* 0.14 ht))
(vla-put-VertCellMargin tab (* 0.14 ht))
(setq lst (cons (mapcar '(lambda (a) (strcat "Col" (itoa (1+ (vl-position a (car lst)))))) (car lst)) lst))
(setq i 0)
(foreach col (apply 'mapcar (cons 'list lst))
(vla-SetColumnWidth tab i
(apply
'max
(mapcar
'(lambda (x)
((lambda (txb) (+ (abs (- (caadr txb) (caar txb))) (* 2.0 ht)))
(textbox (list (cons 1 (vl-princ-to-string x)) (cons 7 (getvar 'textstyle)) (cons 40 ht)))
col
(setq i (1+ i))
(setq lst (cons '("Total Lenght / Upper Thread & Lower Thread") lst))
(setq row 0)
(foreach r lst
(setq col 0 )
(vla-SetRowHeight tab row (* 1.5 ht))
(foreach c r
(vla-SetText tab row col (if (numberp c) (rtos c) (vl-princ-to-string c)))
(setq col (1+ col))
(setq row (1+ row))
do(print upper)
do(print lower)
