Insert image
Insert image
Message 1 of 17
Insert image
Can anyone help me create a lisp to insert a jpg from a file location on my computer. It would basically be the attach command but will just insert the specific file from the location needed at 0,0 -
-attach (attach jpg from location: Libraries\Pictures\IMAGE.JPG)
 insertion point <0,0>
 scale factor <1>
Danny
Replies (16)
Message 2 of 17
pbejse
Danny
(defun c:demo (/ imagefile inimage)
  (if (findfile (Setq imagefile "C:\\Downloads\\IMAGE.JPG"))
    (progn
	  (setq	inimage	(vlax-invoke
			  (vlax-get
			    (vla-get-ActiveLayout
			      (vla-get-activedocument
				(vlax-get-acad-object)
			    'Block
			  'AddRaster
			  imagefile
			  '(0.0 0.0 0.0)
			  44.5			;<-width
			  0.0
	  (vla-put-name inimage "MyInsertedPicture") ;<-- Name
	  (vla-update inimage)
  (princ)
HTH
Message 3 of 17
Im not sure if im doing something wrong but nothing is happening when i run the demo command. I have saved a JPG file in C:\\Downloads and I've named it "IMAGE" . I've saved the lsp file then loaded it into cad, i run the demo command. But nothing happens?
Message 4 of 17
pbejse
The only time it would do nothing when the file is not found:
(defun c:found (/ imagefile)
  (princ
    (if	(findfile (Setq imagefile "C:\\Downloads\\IMAGEs.JPG"))
      (strcat "\nImage found at " imagefile)
      "\nImage not found"
  )(princ)
What do you see when you load and run this?
OR
The image is too small to see. When you type image do you see "MyInsertedPicture" listed on the File REferences dialog?
Message 5 of 17
Just noticed what was wrong, the image wasn't saved in c:\\downloads. I changed it and it works now, thanks.
How would i change the insertion fro 0,0 to insert on the tool tip?
Message 6 of 17
pbejse
Not sure what you mean by that chewdanny12. Is that prompting for insertion point on screen?
Message 7 of 17
Yes, just like when you insert from a tool palette.
Message 8 of 17
pbejse
Are you aware you can use a dwg or dwt file with all your images attached to it and use that file as a source from tool palette?
Otherwise :
Use a lisp code
(defun _insertImage ( imagefile / imagefile inimage p)
  (if (and
	 (findfile imagefile)
	 (setq p (Getpoint "\nInsertion point"))
    (progn
			  (vlax-get
			    'Block
			  'AddRaster
			  imagefile
			  p
			  44.5			;<-width
			  0.0
	  (vla-put-name inimage (vl-filename-base imagefile)) ;<-- Name
    (princ (Strcat  "\nImage file \"" (vl-filename-base imagefile) "\" not found!"))
  (princ)
(_insertImage "C:/Downloads/IMAGE.JPG")
(_insertImage "C:/Downloads/Another_IMAGE.JPG")
HTH
Message 9 of 17
Kent1Cooper
This is all you need:
(command "_.-attach" "C:\\Libraries\\Pictures\\IMAGE.JPG" "0,0" "" "")
Replace the C with the appropriate drive letter if needed.
Kent Cooper, AIA
Message 10 of 17
pbejse
Yes, that too. Smiley Happy
Message 11 of 17
This works too, but how do you insert the image on screen at the tool tip?
I have created a custom button on the ribbon that runs the lisp and inserts the image at 0,0. This works fine, but it would be nice to chose the location point for the insertion.
Message 12 of 17
Kent1Cooper
You don't say whose Post you're Replying to.  If it's my little code string, just replace the "0,0" with a pause for User input:
(command "_.-attach" "C:\\Libraries\\Pictures\\IMAGE.JPG" pause "" "")
Kent Cooper, AIA
Message 13 of 17
That's great thank you. One final thing... i tried entering the scale factor and rotation angles to the lisp, but it still prompts me for each when i run the lisp
(defun c:spo (/ imagefile)
(command "_.-attach" "C:\\Downloads\\IMAGE.jpg" "pause" "2" "45")
Is there something i'm not doing right?
Message 14 of 17
Kent1Cooper
Don't put quotation marks around the word pause.
Kent Cooper, AIA
Message 15 of 17
Brilliant, thanks.
Message 16 of 17
Sea-Haven
Just a side comment had a staff layout plan with each staff members image auto placed based on their telephone extension which was a block with a attribute so phno=image name, would do around 100 images in like 2 seconds.
Message 17 of 17
kishanbG8MQ5
This code works to find and display an image in a CAD file on the local system after saving the file. However, if the saved file is emailed to another person, the image cannot be displayed on their system.
