Insert Elbow Lisp
Insert Elbow Lisp
smallƑish
Message 1 of 32
Insert Elbow Lisp
smallƑish
Select two pipe blocks
Find their intersection point and calculates the rotation.
It inserts an "ELBOW" block at the intersection point with the correct rotation
If it can be automated with lisp please help me
Thank you
Accepted solutions (4)
Replies (31)
Message 21 of 32
smallƑish
Noted, thank you for your reply even though you are busy.
Message 22 of 32
tanbqtb03
Would you like to help me to update code for any other fitting, same function with elbow (elbow block), such as tee block, 45° wye.....or something? Thanks
Message 23 of 32
Moshe-A
@smallƑish hi,
attached the new version
a change in commands name
1. elbowL previously was elbow
2. elbowT this is new
3. l2m - no change
enjoy
Moshe
Message 24 of 32
smallƑish
That's absolutely perfect! going beyond what I requested in the forum. I'm sure this will be helpful for many draftsmen in the future, letting them enjoy piping drafting instead of seeing it as a tedious task. It's simply awesome! Thank you so much!
Message 25 of 32
smallƑish
@Moshe-A
Another question
Currently, we cant able to run the lisp to previsly selected objects, instead we need to select one by one after initiating the comand.
For example, if I select a MLine, use the "Select Similar" option, and then run a command, it asks me to select objects again. Also, "Select Similar" doesn't work after that.
Any chance to make it possible?
Message 26 of 32
DOODLEANU
I know you are asking about this.
which is not possible to code. coz see how complicated to just see 8 angles are there. so keep this way while you work. so easy to copy paste without rotating much that's what I do.
Message 27 of 32
Moshe-A
@DOODLEANU ,
"which is not possible to code"
almost what can be done manually, can be done Programmatically 😀
Message 28 of 32
tanbqtb03
I can't code, so I don't know how difficult it is to code, sorry bro
Message 29 of 32
smallƑish
@DOODLEANU try this
(defun c:IN45 (/ INPOINT LASTBLOCK)
  (setq INPOINT (getpoint "\nPick insertion point: "))
  (command "INSERT" "YOURBLOCK" INPOINT 1 1 0) ; Replace your block name
  (setq LASTBLOCK (entlast))
  (princ "\nROTATE OR ENTER ANGLE")
  (command "ROTATE" LASTBLOCK "" INPOINT)
 hope you can make the process bit easier.
Message 30 of 32
DOODLEANU
why need a code for this ?
use block insertion this option, easy?
Message 31 of 32
DOODLEANU
I mean complicated.
Message 32 of 32
DOODLEANU
Even coding is not my skill too. but this looks difficult to understand while draw manually. then coding may be very difficult that's what I mean.
