insert coordinates not in the spot specified
Ok this is a really wierd one.
the insert is not putting it in the spot specified.  The coordinates in the insert is correct but it puts the object in a different spot for the first time but is correct the rest of the time????   It's driving me crazy lol
projmode is set to 0
osnap os off
grid is off
It just started doing this recently....I think after I upgraded to windows 10.  Before that it all worked fine.
I added in the freeze and thaw layers to try and correct it, which worked for the rest of the program.but doesn't seem to work here.
This is the part of the program that is still acting up... any ideason what is going on????
		(repeat	ldspnm2
		  (setq	ladsuppt
			 (list Tankofmv
			       (+ (+ TANKTOCYL CALC1) EPL1)
			       ldspstart
		  (command "-view" "o" "t")
  (prompt "\n")
  (princ "ladsuppt : ")
  (princ ladsuppt)
  (prompt "\n")
		  (command "layer" "f" "*" "")
		  (command
		    "_insert"
		    "C:/3D Storage Tank Generator/3D files/Ladders/Ladder Supports.DWG"
		    ladsuppt
		  (command "layer" "thaw" "*")
		  (command "explode" "l" "")
		  (setq ldspstart (+ ldspstart ldspspc))
		  (setq CNTR 0)
		  (setq TKCHT1 0)
		  (setq TKCHT2 (nth 0 TCHT))
		  (if (<= TKCHT1 0)
		    (setq TKCHT1 (- TKCHT1 THGT))
		  (if (< TKCHT2 0)
		    (setq TKCHT2 (- TKCHT2 THGT))
		  (repeat NC
		    (cond
		       (and (< TKCHT1 ldspstart) (> TKCHT2 ldspstart))
		       (setq CTHK (nth CNTR TCTT))
		       (setq crsnum CNTR)
		       (setq
			 rpdx1a
			  (- (* TANKTOCYL -1) (+ BTR (/ CTHK 2)))
		    (setq TKCHT1 (+ TKCHT1 (nth CNTR TCHT)))
		    (setq CNTR (+ CNTR 1))
		    (if	(/= (nth CNTR TCHT) nil)
		      (setq TKCHT2 (+ TKCHT2 (nth CNTR TCHT)))
		  (setq rpdy1 (* (* THGT 2) -1))
		  (setq rpdy2 (* THGT 2))
		  (setq pltrpd 2)
		  (setq cnt 1)
		  (repeat pltrpd
		    (cond
		       (= cnt 1)
		       (setq pltlyr "SupTrim3")
		       (setq rpdx1 rpdx1a)
		       (setq sptrm "SupTrim1")
		       (= cnt 2)
		       (setq pltlyr "SupTrim4")
		       (setq rpdx1 rpdx1a)
		       (setq sptrm "SupTrim2")
		    (setq rpdx2 (- rpdx1 0.25))
		    (command "-view" "o" "ba")
		    (command "zoom" "W" winpt1 winpt2)
		    (setq ss   (ssget "X" (list (cons 8 pltlyr)))
			  cntr (1- (sslength ss))
		    (setq ssent nil)
		    (while
		      (>= cntr 0)
		       (setq
			 ssent (append ssent (list (ssname ss cntr)))
		       (setq cntr (1- cntr))
		    (setvar 'clayer pltlyr)
		    (command "extrude" (nth 0 ssent) "" -72)
		    (command "-view" "o" "l")
		    (setq PT1 (list rpdx1 rpdy1 (* Tankofmv -1)))
		    (setq PT2 (list rpdx2 rpdy2 (* Tankofmv -1)))
		    (command "rectangle" PT1 PT2)
		    (setq
		      PT1
		       (list (* TANKTOCYL -1) rpdy1 (* Tankofmv -1))
		    (setq
		      PT2
		       (list (* TANKTOCYL -1) rpdy2 (* Tankofmv -1))
		    (command "revolve" "l" "" PT1 PT2 "" "")
		    (command "layer" "thaw" "*" "")
		    (setq winpt1 (list TDIA (- TDIA (* TDIA 6))))
		    (setq winpt2 (list (- TDIA (* TDIA 2)) TDIA))
		    (setq ssent nil)
		    (while
		      (>= cntr 0)
		       (setq
		    (command "intersect" (nth 0 ssent) (nth 1 ssent) "")
		    (setq ssent nil)
		    (while
		      (>= cntr 0)
		       (setq
		    (setq elist (entget (nth 0 ssent)))
		    (setq
		      elist
		       (subst (cons 8 "Repad") (assoc 8 elist) elist)
		    (entmod elist)
		    (setq cnt (+ cnt 1))
		    (setvar 'clayer "Pipe2")
		    (setq PT1 (list (+ rpdx1 36) rpdy1 (* Tankofmv -1)))
		    (setq
		      PT1
		    (setq
		      PT2
		    (setq ss1  (ssget "X" (list (cons 8 sptrm)))
			  cntr (1- (sslength ss1))
		    (setq ssent1 nil)
		    (while
		      (>= cntr 0)
		       (setq
			 ssent1
			  (append ssent1 (list (ssname ss1 cntr)))
		    (setq ss2  (ssget "X" (list (cons 8 "Pipe2")))
			  cntr (1- (sslength ss2))
		    (setq ssent2 nil)
		    (while
		      (>= cntr 0)
		       (setq
			 ssent2
			  (append ssent2 (list (ssname ss2 cntr)))
		    (command "subtract"
			     (nth 0 ssent1)
			     (nth 0 ssent2)
		    (setq ssent1 nil)
		    (while
		      (>= cntr 0)
		       (setq
			 ssent1
		    (setq elist (entget (nth 0 ssent1)))
		    (setq
		      elist
		       (subst (cons 8 "LADSup") (assoc 8 elist) elist)
		    (entmod elist)
kerry_w_brown
There seems to be a lot of code there that is not related to the issue...
and the important code that sets the insertion point is untestable.
What is the value difference between the actual insertion point and the variable ladsuppt ?
// Called Kerry or kdub in my other life.
Everything will work just as you expect it to, unless your expectations are incorrect. ~ kdub
Sometimes the question is more important than the answer. ~ kdub
NZST UTC+12 : class keyThumper<T> : Lazy<T>;      another  Swamper
kerry_w_brown
and what is the value for
ldspnm2
Tankofmv
TANKTOCYL
CALC1
 EPL1
ldspstart
ldspspc
TCHT
NC
TCTT
etc, etc, etc
The first time through ladsuppt is (1320.0,-1092.94,-151.0) but it places it at (1305.25, -1086.9375, -35) every other time it goes through it places it in the correct spot.
ВeekeeCZ
Check OSNAPZ...
but personally I would put "_none" as osnap in front of each point inserting with command.
(command
		    "_insert"
		    "_none" ladsuppt
Nice 🙂 that did the job.
Still not sure why it all stopped working in the first place but this was the last part that needed to be fixed I think.
thanks for the help
