insert cont. Block
insert cont. Block
k005
Advisor Advisor
Message 1 of 8
insert cont. Block
k005
(defun c:mim (/ bry)
(setvar "cmdecho" 0)
(setvar "OSMODE" 1)
(if (= ant2 nil)(setq ant2 10))
(setq ant2_t (getreal (strcat "\nÖlçek giriniz   <" (rtos ant2 2 2)"> : ")))
(if (= ant2_t nil)(setq ant2_t ant2))
(setq ant2 ant2_t)
(setq bry(getpoint "\nBu noktaya: "))
(command "-insert" "mim01" "scale" ant2 bry  "")
(setvar "cmdecho" 1)
(setvar "OSMODE" 0)
(princ)
D:\Blocks\    «--- Supported...
xxxx01.dwg
xxxx02.dwg
xxxx03.dwg
xxxx04.dwg
Hello to everyone
I have blocks in this order in the folder I specified.
When I run the mim command; How can I call the block with the last numeric value?
(command "-insert" "xxxx04" "scale" ant2 bry "")
Replies (7)
Message 2 of 8
Kent1Cooper
If all the files in that directory are named the same way except for the numerical ending, try this:
(command "-insert"
  (last (vl-sort (vl-directory-files "D:/Blocks" "*.dwg" 1) '<))
  "scale" ant2 bry ""
Kent Cooper, AIA
Message 3 of 8
k005
I added the code. but it doesn't get a block.
Message 4 of 8
Kent1Cooper
What does this by itself return?
Kent Cooper, AIA
Message 5 of 8
k005
@Kent1Cooper  sorry I made a mistake... The code is working.
Thank you so much.
Message 6 of 8
k005
Blocks = is Fixed...
"D:/Blocks"
How can I make it find this path automatically?
well ;
Let him look in the AutoCAD support folders - and find it himself.. how can we do this?
Message 7 of 8
Kent1Cooper
OPTIONS command dialog box:
Kent Cooper, AIA
Message 8 of 8
k005
I know the situation in this part.
I wanted to say, can we have the folders here look through the code?
So if it could be...
Not important. I can edit lisp., or support folders as you mentioned...
