Insert common block
carminatithekid1
Insert common block
carminatithekid1
I would like to create a lisp that will insert a block from my current job folder. Currently I do this manually but I realized that the path is always the same and the block name in always the same as well. This is how it would work;
_insert
search for current job folder, find "temp" folder, and select "btitle.dwg"
insert the dwg file at 0,0
the issue is that every job has a different name, but every job has a temp folder. Is there a way to do this automatically?
What I have come up with is this,
(defun c:bb ()
(command "_insert" "..\temp\btitle.dwg" "o,o"))
It says "invalid block name"
I guess my issue is trying to get the file name correct. Any help is much appreciated as I am new to creating my own lisp.
Randy Carminati
Replies (10)
carminatithekid1
I would like to add one item. The block should be exploded after insert.
Randy Carminati
phanaem
Use (getvar 'dwgprefix) to get the correct path and
(strcat (strcat 'dwgprefix "\\temp\\btitle.dwg")) to get the block name.
You should check if the block is already inserted or if the btitle.dwg really exist.
something like this:
(setq block_name
    (cond
      ((tblsearch "block" "btitle") "btitle")
      ((findfile (strcat (getvar 'dwgprefix) "temp\\btitle.dwg")))
      (T nil)
Then insert the block
(if
    block_name
    (command "_insert" block_name ... )
The command "_insert" arguments depend on your AutoCAD version. You can find the correct ones by typing (command "_insert") at the command prompt and note each required input.
For me, (command "_insert" block_name "_S" 1.0 "_R" 0.0 "_none" '(0.0 0.0)) works well.
To explode the block, use (command "_explode" (entlast)). However, you should check if the (entlast) is actually your block, like this:
(setq last_ent (entlast))
(setq block_name ....
(command "_insert" ....
(if
  (not (eq (entlast) last_ent))
_Tharwat
(if
You can add asterisk before the name of the block and automatically it would be exploded on insertion.
 (command "_.-insert" (strcat "*" block_name) '(0. 0.) "1" "1" "0.0")
john.uhden
Instead of finding files in subdirectories, why not just keep the BTITLE.DWG in the same folder as the current drawing?  That way the insert command doesn't need a path because AutoCAD always looks in the current drawing's path first.  I also agree with the "*" prefix to bring it in exploded.
John F. Uhden
carminatithekid1
From what I understand, of what you wrote. I am doing something wrong.
(defun c:bb ()
(setq block_name
(cond
(T nil)
(if
block_name
Randy Carminati
carminatithekid1
The reason the file isn't in the current directory is because we have 3 disciplines in one office that need access to that file. It makes more sense to us to keep it in a common folder.
Randy Carminati
carminatithekid1
Once I paid some more attention to what you guys were actually saying, I figured it out.
(defun c:bb ()
(setq block_name
(cond
(T nil)
(if block_name
(command "_insert" "btitle.dwg" "0,0" "" "" "")
(if
Works like a charm! Thanks!
Randy Carminati
john.uhden
There is no need to explode the block insertion after the fact.  Plus, you can't explode it if the current layer is locked.
Try this...
(defun c:bb ( / block_name)
  (setq block_name
    (cond
      (T nil)
  (if block_name
    (command "_.insert" (strcat "*" block_name) "0,0" "" "" "")
    (princ "\nBlock name 'BTITLE' not found.")
  (princ)
Of course you should have Undo and error controls.  Want me to add them?
John F. Uhden
wkmvrij
And why would one not put the block in template files one for each discipline in your office and exploded if required. Each user might set the required template  as default....
carminatithekid1
This has been solved. Thanks for replying.
Randy Carminati
