Insert blocks of uniform size scaled according to current drawing
ss6153
ss6153
Hello Reader
I am new to AutoCAD as well as AutoLISP
I have extracted multiple blocks (along with attributes) from a dwg file.
When i insert a few of them into a new drawing space, all of them seem to be of different sizes. I tried to use the same scale factor for all but that didn't work for obvious reasons.
When i insert the blocks into the same file that i extracted them from, they are inserted in uniform size and scale..
I want a lisp routine that will insert these blocks in uniform size and scaled according to whatever drawing they are being inserted into.
Is this possible?? Please help me...
Shneuph
It sounds like you should start by looking into the block's units.  If a block has it's units set to 'meters' for instance, and you insert it into a drawing with units set to 'inches', it can scale the blocks.
Look into the following system variables as well:
insunits
insunitsdefsource
insunitsdeftarget
Edit:
They may also be annotative objects?  I don't use but someone else may be able to help with that.
---sig---------------------------------------
'(83 104 110 101 117 112 104 64 71 109 97 105 108 46 99 111 109)
Sea-Haven
The meters to feet with blocks externally inserted you will find the scale factor is 0.3048 so need a rescale of 1/0.3048.
Like Shneuph check the variables.
ss6153
Hi @Shneuph @Sea-Haven
Thankyou so much for your quick response. I had checked the variables earlier also but didn't look into it in detail because I didn't expect it to solve my problem. After you suggested.. I looked it up online and understood how to solve my issue.
Thankyou for help.
