insert block
insert block
Message 1 of 15
insert block
any one helpe me??
 i want to insert this block with different dimensions (Dynamically)
(defun c:vcd ()
(setq p1 (Getpoint " Second Point: "))
(setq p2 (Getpoint " Second Point: "p1))
(if
;(or
(tblsearch "BLOCK" "vcd")
;(findfile "vcd.dwg")
(command "insert" "vcd" "p1" "p2")
(princ "\n ** Diffuser block not found!")
(princ)
Replies (14)
Message 2 of 15
cadffm
Type in commandline
Command: -INSERT <enter>
and follow the steps of the commandlineversion of command INSERT.
Blockname?
VCD <enter>
Your Input for command Insert "Blockname", Coordinate, Coordinate are not all information what the command want from you.
Open Textscreen to see it easier [F2]
Sebastian
Message 3 of 15
ВeekeeCZ
If you set the variables p1 and p2 like that, then usage within the command later is without quotes.
(command "insert" "vcd" p1 p2)
But I think in your case should be this enough.
(command-s "insert" "vcd") and that is. It's all dynamic.
Message 4 of 15
(defun c:vcd ()
(setq p1 (Getpoint " insertion point : "))
(setq p2 (Getpoint " Secopnd point : "p1))
(setq d (distance p1 p2))
(setq yf (/ d 300))
(if
;(or
(command "_insert" "vcd" p1 yf 1 (angle p1 p2))
(princ)
i almost done but i didn't get rotation properly
Message 5 of 15
ВeekeeCZ
Probably just wrong units.
(angtos (angle p1 p2) (getvar 'AUNITS) 10)
Don't forget to turn the OSNAPs off, you could get unpredictable results.
(command "_insert" "vcd" "_non" p1 "_non" yf 1 (angtos (angle p1 p2) (getvar 'AUNITS) 10))
BTW the length of your block is 360, not 300. (if I follow the idea).
Message 6 of 15
pls explain this command
Message 7 of 15
ВeekeeCZ
See HELP
Its (angtos angle unit presicion).
The point is, that your (angle p1 p2) returns the angle in radians. And you need for (command) drawing units (= AUNITS sysvar). So this makes the conversion.
Message 8 of 15
also i have flip property in may block  how control this action by lisp
can u complete it??
Message 9 of 15
ВeekeeCZ
See HERE
Message 10 of 15
but i dont know how call this function
Message 11 of 15
ВeekeeCZ
Call it by its name!
Message 12 of 15
(defun c:vcd ()
(setq yf (/ d 300))
(if
;(or
(princ)
(defun LM:toggleflipstate ( blk )
(vl-some
'(lambda ( prp / rtn )
(if (equal '(0 1) (vlax-get prp 'allowedvalues))
(progn
(vla-put-value prp (vlax-make-variant (setq rtn (- 1 (vlax-get prp 'value))) vlax-vbinteger))
rtn
(vlax-invoke blk 'getdynamicblockproperties)
Message 13 of 15
can u?? pls
Message 14 of 15
ВeekeeCZ
(vl-load-com)
(LM:toggleflipstate (vlax-ename->vla-object (entlast)))
Message 15 of 15
(defun c:vcd ()
(setq yf (/ d 300))
(if
;(or
(princ)
in this program i can find file only from support folder
how i get in a specific folder???
