Insert block on profile polyline from plan alignment vertexes by horizontal distance (Delta X)
neam
Message 1 of 9
neam
Hi everyone
I write two routines for specify profile pline vertexes to plan alignment. and plan alignment vertexes to profile pline.
but i want insert block from plan vertexes to profile by delta x distance on profile pline.
I would be grateful if you could guide me.
Replies (8)
Message 2 of 9
CADaSchtroumpf
Perhaps this? If I have understood...
((lambda ( / ss ent obj ll ur ss_txt n dxf_ent txt val pt)
  (vl-load-com)
  (setvar "CMDECHO" 0)
  (princ "\nSelect Plan Alignment : ")
  (while (not (setq ss (ssget "_+.:E:S" '((0 . "LWPOLYLINE") (67 . 0) (8 . "C-ROAD-CNTR-N") (62 . 6) (-4 . "<NOT") (-4 . "&") (70 . 1) (-4 . "NOT>"))))))
  (setq
    ent (ssname ss 0)
    obj (vlax-ename->vla-object ent)
  (vla-GetBoundingBox obj 'll 'ur)
  (setq
    ll (safearray-value ll)
    ur (safearray-value ur)
  (command "_.zoom" "_w" ll ur)
  (setq ss_txt (ssget "_C" ll ur '((0 . "MTEXT"))))
  (cond
    (ss_txt
      (princ "\nSelect Profile Pline: ")
      (while (not (setq ss (ssget "_+.:E:S" '((0 . "LWPOLYLINE") (67 . 0) (62 . 4) (-4 . "<NOT") (-4 . "&") (70 . 1) (-4 . "NOT>"))))))
      (setq ent (ssname ss 0))
      (repeat (setq n (sslength ss_txt))
        (setq
          dxf_ent (entget (ssname ss_txt (setq n (1- n))))
          txt (vl-string-left-trim "PVI\nKM.=" (cdr (assoc 1 dxf_ent)))
          val (atof (vl-string-subst "" "+" txt))
          pt (vlax-curve-getPointAtDist ent val)
        (command "_.-insert" "Pick" "_none" pt "" "" "")
        (command "._text" "_none" pt "" "90" (strcat "PVI=" txt))
  (setvar "CMDECHO" 1)
  (prin1)
Message 3 of 9
Sea-Haven
This is a tick button in other addon software a default style of answer and produces multiple sheets where required for long alignments. Look for company name in image.
Message 4 of 9
neam
Hi dear cadaschtoumpf:
Thank you for your attention
I want the km of each vertex of the plan to be shown on the profile polyline.
This is possible when we introduce a straight polyline as a profile.
But when the profile polyline has multiple failures, the value of Delta X should be implemented on it.
(I apologize for my poor English.)
Message 5 of 9
neam
Hi dear sea-haven
This operation is easily possible in autocad civil 3d.
But I deal with AutoCAD objects in maps that are given to me by other people.
Message 6 of 9
CADaSchtroumpf
Not sure I understand, but try this...
For 'Profile Pline' do not select the straight cyan polyline but the one with many vertices. (contrary to the previous proposition)
((lambda ( / ss ent lg obj ll ur ss_txt k n dxf_ent txt val pt)
  (vl-load-com)
  (setq
    ent (ssname ss 0)
    lg (vlax-curve-getDistAtParam ent (vlax-curve-getEndParam ent))
  (setq
  (cond
    (ss_txt
      (setq
        ent (ssname ss 0)
        k (/ (vlax-curve-getDistAtParam ent (vlax-curve-getEndParam ent)) lg)
        (setq
          lg (* k val)
          pt (vlax-curve-getPointAtDist ent lg)
  (prin1)
Message 7 of 9
neam
Hi
I sent the sample file to clarify my question.
Message 8 of 9
CADaSchtroumpf
OK, I think that I have understood.
((lambda ( / ss_pa ent_pa obj ll ur ss_bl AcDoc Space ss_pl obj_pl pt_ori n dxf_ent lg startPoint endPoint nw_line pt d1 d2 d3 d4 d5 txt e1 ee1)
  (vl-load-com)
  (while (not (setq ss_pa (ssget "_+.:E:S" '((0 . "LWPOLYLINE") (67 . 0) (8 . "C-ROAD-CNTR-N") (62 . 6) (-4 . "<NOT") (-4 . "&") (70 . 1) (-4 . "NOT>"))))))
  (setq
    ent_pa (ssname ss_pa 0)
    obj (vlax-ename->vla-object ent_pa)
  (setq
  (setq ss_bl (ssget "_C" ll ur '((0 . "INSERT") (2 . "IP"))))
  (cond
    (ss_bl
      (setq
        AcDoc (vla-get-ActiveDocument (vlax-get-acad-object))
        Space
        (if (= 1 (getvar "CVPORT"))
          (vla-get-PaperSpace AcDoc)
          (vla-get-ModelSpace AcDoc)
      (while (not (setq ss_pl (ssget "_+.:E:S" '((0 . "LWPOLYLINE") (67 . 0) (62 . 4) (-4 . "<NOT") (-4 . "&") (70 . 1) (-4 . "NOT>"))))))
      (setq
        obj_pl (vlax-ename->vla-object (ssname ss_pl 0))
        pt_ori (vlax-curve-getStartPoint obj_pl)
      (repeat (setq n (sslength ss_bl))
        (setq
          dxf_ent (entget (ssname ss_bl (setq n (1- n))))
          lg (vlax-curve-GetDistAtPoint ent_pa (vlax-curve-getClosestPointTo ent_pa (cdr (assoc 10 dxf_ent)) nil))
          startPoint (vlax-3d-point (list (+ (car pt_ori) lg) (cadr pt_ori) (caddr pt_ori)))
          endPoint (vlax-3d-point (list (+ (car pt_ori) lg) (+ (cadr pt_ori) lg) (caddr pt_ori)))
          nw_line (vla-AddLine Space startPoint endPoint)
          pt (vlax-invoke obj_pl 'IntersectWith nw_line 3)
          d1 (substr (rtos lg 2 2) 2 1)
          d2 (substr (rtos lg 2 2) 3 1)
          d3 (substr (rtos lg 2 2) 4 1)
          d4 (substr (rtos lg 2 2) 5 1)
          d5 (substr (rtos lg 2 2) 6 1)
        (if (= d1 ".")
          (setq txt (strcat "0+00" (rtos lg 2 2)))
        (if (= d2 ".")
          (setq txt (strcat "0+0" (rtos lg 2 2)))
        (if (= d3 ".")
          (setq txt (strcat "0+" (rtos lg 2 2)))
        (if (= d4 ".")
          (setq
            e1 (substr (rtos lg 2 2) 1 1)
            ee1 (substr (rtos lg 2 2) 2 8)
            txt (strcat e1 "+" ee1)
        (if (= d5 ".")
          (setq
            e2 (substr (rtos lg 2 2) 1 2)
            ee1 (substr (rtos lg 2 2) 3 8)
            txt (strcat e2 "+" ee1)
        (entdel (entlast))
        (command "._text" "_none" pt "" "90" (strcat "PI=" txt))
  (prin1)
Message 9 of 9
neam
HI Dear CADaSchtroumpf:
Thank you very much for your time to solve my problem.
