Insert Block and directly move attribute
C.Utzinger
Message 1 of 24
C.Utzinger
HI
Is it possible to insert the attached block and directly move the Attribute with a lispcode?
I mean first you select the instertpoint for the block and the the Location Point for the Attribute.
Please help....
Accepted solutions (3)
Replies (23)
Message 21 of 24
C.Utzinger
Hi again 😞
A question to the getpoint part.
(getpoint (trans (vlax-get itm 'TextAlignmentPoint) 0 1) "\nTextposition angeben: ")
Is it posible to see the text moving, or a shadow, or a rectangle, or somehting else?
Kind regards
Message 22 of 24
pbejse
@C.Utzinger wrote:
....Is it posible to see the text moving, or a shadow, or a rectangle, or somehting else?
Really Cree-G?
GRREAD <---- Read this
(defun _NextTrick (pt obj / end code pt2)
      	(while
              (and (null end)  (setq p (grread t 15 0) code (car p)))
                      (cond
                            ((= 5 code)
                             (vlax-put obj 'TextAlignmentPoint (setq pt2 (trans (cadr p) 1 0)))
			     (setq pt pt2)
                            ( (or (= 2 code)(= code 3))
                                 (setq end T)))
command: IBDMA <---- Insert Block and Directly Move Attribute
HTH (again)
Message 23 of 24
C.Utzinger
Sorry! I have no more questions, now it's perfect.
Thank you very much for the the link and lesson.
I learned again so much!!!!
And nice Image Smiley LOL
Kind regards
Message 24 of 24
pbejse
@C.Utzinger wrote:
Sorry! I have no more questions, now it's perfect....Thank you very much for the the link and lesson.... I learned again so much!!!!
Excellent!
You are welcome.
