Insert a block and then xclip it
newEagle
Message 1 of 8
newEagle
I am using command to insert a block, after which I'd like to xclip the bock just inserted.
Something like:
(setq name "blockName")
(command "-insert" name (list x y) 1 1 ROT)
;;Here's where I want to xclip the block inserted above
Replies (7)
Message 2 of 8
ronjonp
Perhaps:
(command "_.-insert" (setq name "blockName") (list x y) 1 1 ROT)
(command "_.xclip" (entlast) "")
Message 3 of 8
newEagle
Thanks. With some additions I got that to work. Not sure why I couldn't get it before.
Message 4 of 8
ronjonp
@newEagle Glad to help. 🙂
What does your xclip look like on the inserted block?
Message 5 of 8
newEagle
The pill shaped label is annotative. At certain scales, it grows beyond the bounds of the box it's in. XCLIP was just what I needed.
Message 6 of 8
ronjonp
@newEagle So you are placing all those 'pills' one by one into a table?
Message 7 of 8
newEagle
The block is a rectangle with the pill shaped labels. They are placed automatically in a grid shape according to specifications. To account for different scales I've made the labels annotative. Before I had to go thru each block and change the labels to proper size.
Message 8 of 8
ronjonp
Good to hear you have some automation. 👍
The process looked tedious that's why I asked.
