Incremental Numbering Suite (NumInc) Object Snap
thomas_schluesselberger
Message 1 of 8
Hello!
I have a question about the awesome LISP that LeeMac made.
Unfortunately, when I use the LISP with blocks (without the array function), the object snap don't work.
Is there a way to enable object snap while placing blocks?
I know that there is following Note in the Code:
;;  Note: As a result of the method used to display the real-time preview, Dynamic Mode       ;;
;;  restricts the use of standard AutoCAD functionality such as Object Snap, Orthomode,       ;;
;;  Tracking etc. To enable such functionality, uncheck the 'Text Follows Cursor' option at   ;;
;;  the top-left corner of the dialog.                                                        ;;
But if somehow possible i would like to see Blocks in real-time preview and be able to use Object Snap.
Here the Link to the LISP:
http://www.lee-mac.com/numinc.html
The LISP is also found in the attachments.
Replies (7)
Message 2 of 8
Gobel_A
You have to allow Object Snap (grid snap etc) before using NUMINC. Than it will follow the settings.
Message 3 of 8
the problem is, that this is only working when "Text Follows Cursor" is deactivated.
Message 4 of 8
Moshe-A
@thomas_schluesselberger hi,
This lisp works under AutoLISP limitation. when you want to have dragging [implameted by (grread) function] the osnap is automatically disabled.
You can not have it all-in-one 😀
Moshe
Message 5 of 8
Ok, that's sad, I almost thought so.
Still, thanks for the answer!
Message 6 of 8
jagdish_gaonkar
dear i need separate increment for Perfix, Middle and suffix can it is possible...
Message 7 of 8
jagdish_gaonkar
Message 8 of 8
jagdish_gaonkar
I don't mean that i need as the below sample. Prefix-Middle-Suffix
Exp. P1-M1-S1, P1-M1-S2, after P1-M2-S3, P1-M2-S4, P1-M3-S5. Like that only.
