imprint multiple objects
Message 1 of 9
I need a lisp that imprint multiple objects at the same time (by window selection, lines and polylines) into 3d solid
Replies (8)
Message 2 of 9
Kent1Cooper
More information is needed, and an image or sample drawing would be better still.  What does it mean to "imprint" a Line "into" a 3D Solid?  If you want to carve something out of the surface of the Solid, you will need to base it on something more than a Line, which [being only one-dimensional] has no volume that can be Subtracted [or added, if you want something raised above the Solid surface], but a Polyline with width could be Extruded into something with volume that could be Subtracted from [or added to] the Solid.  Or do you only mean you want to put Lines and Polylines onto the surface of a Solid?  Does the solid have flat surfaces that Lines and Polylines could be drawn on?  Etc., etc.
Kent Cooper, AIA
Message 3 of 9
i want imprint muliple coplanaire 2d lines on a 3d solid to create additional edges on planar faces , because imprint commande imprint 2d geometrie one by one and ask me if i want to delete source  whenever
thanks
Message 4 of 9
hmsilva
Hi majdov24,
a quick and dirty solution...
The 'demo' is not testing if a valid object (with intersection edges) is selected by the user, if an invalid object is selected, the code will throw an error...
Sorry, I have a deadline to meet, so at the moment, I don't have much free time.
(defun c:demo (/ a b itm num ss ss1)
  (if (and (princ "\nSelect a 3D solid or surface: ")
	   (setq ss (ssget "_+.:E:S:L" '((0 . "3DSOLID,*SURFACE"))))
	   (princ "\nSelect objects to imprint: ")
	   (setq ss1 (ssget "_:L" '((0 . "ARC,CIRCLE,LINE,*POLYLINE,ELLIPSE,SPLINE,REGION,3DSOLID"))))
    (progn
       (setq itm 0 num (sslength ss1))
      (command "_.imprint" (setq a (ssname ss 0)))
      (while (< itm num)
	(if (not (eq a (setq b (ssname ss1 itm))))
	  (command b "_Y");; change to N if you don't want to delete
	(setq itm (1+ itm))
      (command "")
  (princ)
Hope that helps
Henrique
Message 5 of 9
Kent1Cooper
@Kent1Cooper wrote:
....  What does it mean to "imprint" a Line "into" a 3D Solid?  ....
[Never mind me -- Imprint is a command in newer versions, that I wasn't familiar with, and hand't run into since I don't often work in 3D.]
Kent Cooper, AIA
Message 6 of 9
rhgrafix
That's awesome! Thanks for writing that, I've been wanting this for years! I know it was a quick write from you and you have the skills to include the choice of keeping or deleting the imprinted entities, I don't. For now I will just make a copy of them and re-merge them. Hard to believe Autodesk doesn't include the choice for multiple Imprints after all these years, hmm.
Thanks again!
Message 7 of 9
hmsilva
Untested...
(defun c:demo (/ a ans b itm num ss ss1)
	   (progn
	     (initget "Y N")
	     (setq ans (cond ((getkword "\nDelete the source object [Yes/No] <N>: "))
			     ("Y")
    (progn
      (setq itm	0
	    num	(sslength ss1)
      (while (< itm num)
	  (command b (strcat "_" ans))
	(setq itm (1+ itm))
      (command "")
  (princ)
Hope this helps,
Henrique
Message 8 of 9
rhgrafix
 That works perfectly! I did change one thing, the prompt asks: "Enter rotation angle" instead of: "Keep entities?"  I assume you pasted some code from a similar macro or something.
Thanks again!
R.L. Hamm
Message 9 of 9
rhgrafix
 Actually if someone could add the choice to this shorter code, it would be the ultimate macro:
https://www.cadtutor.net/forum/topic/48753-command-imprint-for-multiple-objects/?do=findComment&comm...
-=(R)=-
