Importing multiple DXF files into a drawing from a user defined directory?
I found this code while searching online, but I need to be able to pick a new directory folder each time I run the lisp. It would preferably open a file navigation dialog box, so I could browse to the desired folder. Anyone have ideas? Please and thank you!
(defun c:IDXFS (/ directory files)
(setq directory "C:\\MyFile\\DXFs")
(if (setq files (vl-directory-files directory "*.dxf" 1))
(foreach dxf files
(command "_.-insert"
(strcat directory "\\" dxf)
'(0. 0. 0.)
(princ "\n No DXF files found into that folder !")
(princ)
Ranjit_Singh
replace "setq directory ......" with this and once you select any file in the directory it passes the path of the folder to directory variable
(setq directory (vl-filename-directory (getfiled "Select any file in subject directory" "" "" 2)))
Awesome! Thank you!
Ranjit_Singh
welcome!
