Image background color by lisp
a.dellaragione
a.dellaragione
I have a lot of DWGs files that contain some raster images and I would like to automatically set the transparency color
(maybe by a lisp or some code).
Someone can help me?
 Thanks  a lot.
jrreid
I have a similar setup for Images to Turn the Frame Image off by clicking a Button I made.
Type CUI and you can easily make your own Button and then Drag and Drop it onto your screen.
No lisp file needed.
My code is Image Frame Off.  ^C^Cimageframe;0;
But you can make one by adding all of the commands you use to make your Image Transparent.
This is one way to change the layer color:    ^C^C-la;c;211;;;
If I want my layer to be transparent this is what I did manually:
Command:
-LAYER
Current layer: "A-DETL-THIN"
Enter an option [?/Make/Set/New/Rename/ON/OFF/Color/Ltype/LWeight/TRansparency/MATerial/Plot/Freeze/Thaw/LOck/Unlock/stAte/Description/rEconcile/Xref]: tr
Enter transparency value (0-90): 50
Enter name list of layer(s) for transparency 50% <A-DETL-THIN>:
Now to put it in the Button:  ^C^C-la;TR;50;;;
If you need to set your layer first:  ^C^C-la;S;YOURLAYER-TO-BE-TRANS;TR;50;;;
If you want to set the original layer back just add it:  ^C^C-la;S;YOURLAYER-TO-BE-TRANS;TR;50;S:ORIG-LAYER;;;
Make a new Box Image or use one that is there already drawn up.
Should be easy to do.
Hope this helps.
JRR.
Sea-Haven
Maybe this as an example you can add the input value etc
(setq obj (vlax-ename->vla-object (car  (entsel "Pick image"))))
(vla-put-entitytransparency obj 50)
