Illegal Variable Names
john.uhden
Mentor Mentor
Message 1 of 11
john.uhden
I guess I never studied this before (in 40 years), but I stumbled on AutoLisp disliking a variable named A'.
I'm sure there are plenty others (names), but I thought I would just pass this along as a warning to those who like to use unique variable names.
John F. Uhden
Replies (10)
Message 2 of 11
hak_vz
Command: (setq  c'  100)
100
Command: (+  c  100)
200
Command: (+  c'  100)
200
Command: !c'
'_>
Variable name is looked without quote
Command: (setq  a'b  50)
; error: syntax error
Miljenko Hatlak
Message 3 of 11
dlanorh
I always run anything i'm not sure of through snvalid
I am not one of the robots you're looking for
Message 4 of 11
devitg
@john.uhden  if you would use VLIDE as a LISP editor , you will notice that such char to be painted as control Char, as to be not allowed
the brown painted is not allowed
You can use all the shift+number
(setq a!@#$%^&* 100)
(+ a!@#$%^&* 4)
104
(setq a:{}][~`® 400)
400
Also a especial, like ® from alt+0174
 and math operator too
(setq a!@#$%^&*+-?/\ 500)
(+ a!@#$%^&*+-?/\ 4)
500
504
also it
(setq a!@#$%^&*+-?/\<>:: 500)
(+ a!@#$%^&*+-?/\<>:: 7)
500
507
it seem to be that ' " ; are not allow.
Message 5 of 11
john.uhden
Hmmm. I wonder if Textpad has such a feature.
I doubt it though because we use apostrophes legally as well.
John F. Uhden
Message 6 of 11
devitg
@john.uhden , The one million question, why not to use VLIDE?
Message 7 of 11
Sea-Haven
If Johns like me when VLIDE locks up your Autocad its a pain all the resets are locked out CTRL ALT DEL is only way unless you know some secret to truly doing a reset of vlide. Next time I have code that does it will send it to you.
I tend to write and test as I go.
Message 8 of 11
martti.halminen
What is happening here is that a single quote is not an ordinary character in Lisp, it is defined as a reader macro.
The Lisp user interface runs a so-called read-eval-print loop, often abbreviated as REPL. It is essentially just
(loop (print (eval (read))))
- with prompting, error handling etc. added.
So when you call READ, it expands all the reader macroes before giving the result to EVAL.
The behaviour of ' is to convert the next Lisp item into a call to the QUOTE function:
(read "(setq c' 100)")   ->  (SETQ C (QUOTE 100))
This happens with no regard to the syntactic correctness, EVAL has to handle that. So
$ (read "(setq a'b 50)")
(SETQ A (QUOTE B) 50)
- which doesn't make sense so you get an error in EVAL.
The previous was all normal Lisp behaviour, you'd get similar behaviour on any Lisp.
A somewhat similar thing happens with a period, but that is strictly an Autodesk oddity:
(setq a.b 42)  doesn't cause any error reports, but behaves rather differently than most users would expect.
In Common Lisp that would be fully legal, setting the value of the variable A.B, but in AutoLISP, that sets the value of A instead.
_$ (setq a 'something)
SOMETHING
_$ (setq a.b 42)
42
_$ a.b
42
_$ a
42
_$ (read "a.b")
A
So what is happening, when reading a symbol name, the AutoLISP reader stops reading when encountering a period, uses what was read so far as the result and ignores the rest, with no warning whatsoever.
- creates rather interesting bugs if you are not familiar with this behaviour.
As these characters are fully legal elsewhere in a program, a programming environment can't catch these unless it also runs a full syntactic analysis.
Message 9 of 11
devitg
@Sea-Haven I always do test and try line by line.
I had such a problem with some command as Explode, please send me such LISP .
Regards
Message 10 of 11
hak_vz
@martti.halminenThank you for detail explanation
Miljenko Hatlak
Message 11 of 11
john.uhden
@devitg :
That's comforting to know.  Thanks for all that effort.
BTW, I use 2pi and 1/2pi and 3/2pi a lot because I don't want to keep repeating operations and typing.
John F. Uhden
