if selection set then ......
neam
Message 1 of 10
neam
hi every body
I have a selection set (by (ssget "X".........) that sometimes includes:
1-many objects (text and mtext and maybe lwpolyline)
and sometimes:
2-includes two objects (one text and one lwpolyline)
How can I just delete text if it is the first(1) mode?
How can I clear selection set if it is the second(2) mode?
Thank you for your help
Replies (9)
Message 2 of 10
Kent1Cooper
If, when it contains only two objects, it is always and only those particular two kinds, and if  ss  is the variable name, how about....?
(if (> (sslength ss) 2)
  ();;;; then -- delete Text [do you know how to do that?] .... [also Mtext?] ....
  (setq ss nil); else -- clear selection set
); if
Kent Cooper, AIA
Message 3 of 10
neam
Hi kent1cooper
thank you for reply
yes I want delete just only text object when is (>(sslength ss) 2)
Message 4 of 10
Kent1Cooper
Conveniently, you can have it find the Text objects from within the  Previous selection:
  (command "_.erase" (ssget "_P" '((0 . "TEXT"))) ""); then
); if
[That doesn't account for possible locked Layers, but it could be made to, if necessary.]
Kent Cooper, AIA
Message 5 of 10
neam
Dear kent1cooper
your answer is absolutely correct when my selection set more than 2 objects.
but:
if selected objects is equal to 2 entities (text and polyline) then clear selection set.
If selected objects Is equal to 2 entities (text and mtext) then erase only text object.
Message 6 of 10
Kent1Cooper
That combination was not among the possibilities in your original description, nor did you answer the first sentence in Message 2 with any qualifications.  That can be done, but are there any other possibilities you haven't listed yet?
Kent Cooper, AIA
Message 7 of 10
neam
You are completely right.
The main reason for this error is that my English is weak.
I no haven't other possibilities in listed.
thank you very much Because of the time you left for me.
Message 8 of 10
pbejse
Since you are using (ssget "X"),  then included a filter for ONLY Mtext.
(ssget "X" '((0 . "MTEXT")))
or better yet, use other filters to limit the selection that meets your requiements, like layer , position, string value...
Erase on the drawing or remove from the selection?
Message 9 of 10
Kent1Cooper
How about this?  If you have only three possible situations, and you want to erase all the Text objects in two of them [more than 2 objects, or Text + Mtext], then all you need to do is test for the 3rd situation [2 objects including a Polyline].  Minimally tested:
(if (and (= (sslength ss) 2) (ssget "_P" '((0 . "*POLYLINE"))))
  (setq ss nil); then -- clear selection
  (command "_.erase" (ssget "_X" '((0 . "TEXT"))) ""); else -- erase Text
); if
If your (ssget "X" ...) establishing the selection set included filtering, such as by Layer or in only the current space, include the same filtering in the (ssget) in the Erase command.
Kent Cooper, AIA
Message 10 of 10
neam
Tank you very much kennet
I tested your solution in my work and came up with the desired result
Thanks again
