If clause linked to block's attributes
k.tsolidis
k.tsolidis
Hello everyone,
I have a lot of blocks with attributes and I am exporting them in a spreadsheet. Through this procedure, I am able to change my data (attribute’s insertions) simultaneously to a lot of blocks and import it again to my .dwg file (express tools->import attributes).
I was wondering, if there is any possibility, when I import the new attributes from the excel file, to have something like an if clause running in my drawing, for Example: “If attribute’s value is _____ then change block's color to _____” or “If attribute’s value is _____ then replace block _____ with _____”
Is there any other way to achive the above?
I don’t know many thinks about scripts, so any information would be helpful,
Thank you in advance.
David_W_Koch
That could be done with a custom command.  One way to do that would be to use AutoLISP.
David Koch
AutoCAD Architecture and Revit User
Blog | LinkedIn
k.tsolidis
David_W._Koch Thank you for your response.
I would appreciate it if you could show me how to do it!
I don't really know how to write this specific "IF" command, as well as I am not familiar to AutoLISP.
DannyNL
Can you provide an example drawing to show what you have and what you need.
Also include some information on when what should be changed.
