if and conditional help to compare (apply 'max of a list to a (car pt of inters
Message 1 of 25
    I'm trying to compare the results of
        a minimum or maximum apply
with
        the fisrt position of a list that is the (car of a coordinate given by inters command)
the values are the same but the results are always nil for both expressions
      (if (= xMax1 (car pts1234)) (progn (setq x1(/ (+ xMin1 (car pts1234)) 2.00)) ))
      (if (= xMin1 (car pts1234)) (progn (setq x1(/ (+ xMax1 (car pts1234)) 2.00)) ))
what is wrong?
the important part of the code and the results
_$ (setq pt1 (cdr (assoc 10 (entget ocd_line)))) ; 1
(-184.619 265.883 0.0)
_$ (setq pt2 (cdr (assoc 11 (entget ocd_line))))
(-145.645 265.883 0.0)
_$ (setq xl1 (list (car pt1) (car pt2)))
(-184.619 -145.645)
_$ (setq xMax1 (apply 'max xl1))
-145.645
_$ (setq xMin1 (apply 'min xl1))
-184.619
_$ (setq yl1 (list (cadr pt1) (cadr pt2)))
(265.883 265.883)
_$ (setq yMax1 (apply 'max yl1))
265.883
_$ (setq yMin1 (apply 'min yl1))
265.883
_$ (setq pt3 (cdr (assoc 10 (entget obc_line))))
(-184.619 294.473 0.0)
_$ (setq pt4 (cdr (assoc 11 (entget obc_line))))
_$ (setq xl2 (list (car pt3) (car pt4)))
(-184.619 -184.619)
_$ (setq xMax2 (apply 'max xl2))
-184.619
_$ (setq xMin2 (apply 'min xl2))
-184.619
_$ (setq yl2 (list (cadr pt3) (cadr pt4)))
(294.473 265.883)
_$ (setq yMax2 (apply 'max yl2))
294.473
_$ (setq yMin2 (apply 'min yl2))
265.883
_$ (setq pts1234 (inters pt1 pt2 pt3 pt4))
_$ (if (= xMax1 (car pts1234)) (progn (setq x1(/ (+ xMin1 (car pts1234)) 2.00)) ))
nil
_$ (if (= xMin1 (car pts1234)) (progn (setq x1(/ (+ xMax1 (car pts1234)) 2.00)) ))
nil
xMin1 and (car pts1234) has the same value as follow
_$ (car pts1234)
-184.619
_$ xMin1
-184.619
should be something like that: (if (= -184.619 -184.619) (progn (setq x1(/ (+ xMax1 (car pts1234)) 2.00)) ))
Why is not returning TRUE to the sentence to execute the x1 calculation??? (if (= xMin1 (car pts1234)) (progn
Because the x1 remains ZERO as set before
_$ x1
0
Thanks in advance,
Luis
Replies (24)
Message 21 of 25
It seems work out well. I need to test in a larger drawing code.
Message 22 of 25
Hi Kent,
_$ (if (= flag 1) (progn (setq mPt12(list x1 y1)) )) ; ocd_line
_$ (if (= flag 1) (progn (setq mPt34(list x2 y2)) )) ; obc_line
_$ (if (= flag 1) (progn (command "line" mpt12 mpt34 "" "") )) ; new line
_$ (if (= flag 1) (progn (setq mpts (entlast)) )) ; new line
_$ (if (= flag 1) (progn (COMMAND "ZOOM" "OBJECT" mpts "") )) ; new line
_$ (if (= flag 1) (progn (entdel mpts) )) ; new line
_$ (if (= flag 1) (progn (command "._fillet" (osnap mPt12 "nea") (osnap mPt34 "nea") ) ))
It seems work out well. I need to test in a larger drawing code. I'll probably need to use ZOOM EXTENT in some point after the ZOOM OBJECT mpts.
Message 23 of 25
Hi Kent,
But maybe I'll need to insert a ZOOM EXTENT in some point after the ZOOM OBJECT
(command "ZOOM" "E")
Thanks!
Message 24 of 25
It seems work out. I need to test in a larger drawing code.
Message 25 of 25
Thanks a lot Kent.
It finally work out with the addition of these code lines.
_$ (if (= flag 1) (progn (command "._fillet" (osnap mPt12 "nea") (osnap mPt34 "nea") ) )) ; same line that was unstable before now it's working/
_$ (if (= flag 1) (progn (COMMAND "PLAN" "" "") ))
