I would like to create a lisp that goes through all dwg in a folder and perform a command.
SChoi7JGJZ
SChoi7JGJZ
I have about 100 dwg files that were sent from another company in a folder. Unfortunately, all of these dwg files were not saved by an Autodesk application and I need to fix it before proceeding with design. I would like to create a lisp that goes through each drawing in the folder and perform the command "Exporttoautocad". Any guidance to do this will help. Thank you.
DGCSCAD
Unless you're really wanting to create this LISP on your own, you could see if these meet your needs:
https://lee-mac.com/scriptwriter.html
https://help.autodesk.com/view/OARX/2025/ENU/?guid=AUTOCAD_CORE_CONSOLE
(The link for this ^ one is redirecting, so see the TOC at left)
AutoCad 2018 (full)
Win 11 Pro
paullimapa
in addition there are also these:
1. ScriptPro (originally developed by Autodesk but has since dropped further development) offers the option to run a script file on multiple selected drawings. You can download the installer here.
2. AutoScript (similar to ScriptPro) which is a free add-on that gives you the capability of selecting multiple drawings to run a script file
Paul Li
IT Specialist
@The Office
ec-cad
"lisp that goes through each drawing in the folder and perform the command "Exporttoautocad".
Hmm.
What software has created these 'drawings'. If they will 'load' into AutoCAD, seems like you
could just (command 'saveas' "" filename "Y") to overwrite them as native Acad.
Your post says you want to do 'Exporttoautocad', implies you are (not) in autocad, but in
some other software that contains that command.
So, I am not sure what the case is.
ECCAD
