I want to count bolts
avinash00002002
Message 1 of 8
avinash00002002
Hi!
I have some text for bolt and it needs to count.
3-M16x40
Qty-Bolt Size X length
qTY VARY 1 TO n NUMBER
bolt size it shall be M12, M16, M20, M24
BOLT LENGTH = 30 TO 200MM.
IT WILL BE MIXTED BOLT SIZES and it includes with *, "*" means antitheft bolt e.g. 3-M16x40*
it has also mixed text with pack washer 3-M16x40
qty. - PW16 X thickness of washer.
ATTACHED DRAWING ALSO.
Replies (7)
Message 2 of 8
hak_vz
(defun c:cbolts ( / LM:Unique string_to_list count_items ss i j bolts bolts_counts bolt_names item);
	(defun LM:Unique ( l )(if l (cons (car l) (LM:Unique (vl-remove (car l) (cdr l))))))
	(defun string_to_list ( str del / pos )
		(if (setq pos (vl-string-search del str))
			(cons (substr str 1 pos) (string_to_list (substr str (+ pos 1 (strlen del))) del))
			(list str)
	(defun count_items (x lst / count)(setq count 0)(foreach y lst (if (equal x y) (setq count (1+ count)))) count)
	(setq ss (ssget '((0 . "TEXT")(8 . "5_Bolts"))) i -1 bolts_counts (list))
	(cond
		((and ss (>= (sslength ss) 1))
			(while (<(setq i (1+ i)) (sslength ss))
				(setq item (string_to_list  (cdr (assoc 1 (entget (ssname ss i)))) "-"))
				(setq j -1)
				(while (< (setq j (1+ j)) (atoi (car item)))(setq bolts (cons (cadr item) bolts)))
			(setq bolt_names (vl-sort (LM:Unique bolts) '<))
			(foreach bolt bolt_names(setq bolts_counts (append bolts_counts (list (count_items bolt bolts)))))
			(setq i -1)
			(while (< (setq i (1+ i)) (length bolt_names))(princ (strcat "\n" (nth i bolt_names) "," (itoa(nth i bolts_counts)))))
		(T (princ "\nNothing selected!"))
	(princ)
(princ "\nType CBOLTS to count bolts types textmarks!")
(princ)
Miljenko Hatlak
Message 3 of 8
Sea-Haven
Very nice @hak_vz, pretty simple to change the while on line 23 to make a list then can add a table with results.
("PW16x6 3" "M20x60* 3" "M20x50* 15" "M20x45* 6" "M20x40* 12" "M16x50* 32" "M16x45* 37" "M16x40* 88")
Message 4 of 8
Pihu_2024
Dear Sir,
Please modify this Programming, Required Bolt Count Table List Place in text.
Message 5 of 8
hak_vz
@avinash00002002  @Pihu_2024
There are many scripts about transferring result to table.
I would really like to see you trying to write some code.
If you don't learn how to write autolisp code, all our effort is meaningless.
Miljenko Hatlak
Message 6 of 8
hak_vz
@Sea-Haven Yes it is butt I would like OP to come up with some code.
Idea is to make this forum better and to guide new members to learn how to write some code.
How many times have you answered similar requests like this one?
There are so many redundant posts, that all older and very valuable code stored in posts older than 10 years will be moved to backups
and I don't know will it be easily accessible.
This forum is because of this redundancy miles away to forums like theswamp.org.
Miljenko Hatlak
Message 7 of 8
Sea-Haven
Agree @avinash google make a table from a list, there are plenty of examples here.
Message 8 of 8
ec-cad
This model of the Lisp above, adds a simple 'Text' report of the items selected.
ECCAD
