Announcements
i WANT TO AUTO UPDATE ALL BLOCKS WITH Z HIGHT WITH LISP
jlootsCB78E
jlootsCB78E
Hi I'm new to this
I have a large number of blocks in my drawing with the same field "UTILITY_INVERT".
they all the different z values, and i want to update all the fields in one go without to edit them manually.
Can someone direct me in the right direction
Replies (8)
Moshe-A
@jlootsCB78E  hi,
check this COZ (Common Z) command.
enjoy
Moshe
(vl-load-com) ; load activex support
; common z value
(defun c:coz (/ askdist ; local function
	        adoc ss ename elist)
 (defun askdist (def / ask)
  (if (not (setq ask (getdist (strcat "\nSpecify common Z <" (rtos def 2) ">: "))))
   (setq ask def)
   (setq def ask)
 ); askdist
 ; here start c:coz
 (setq adoc (vla-get-activedocument (vlax-get-acad-object)))
 (vla-startUndoMark adoc)
 (if (and
       (setvar "userr5" (setq z (askdist (getvar "userr5"))))
       (setq ss (ssget "_:L" '((0 . "insert"))))
  (foreach ename (vl-remove-if 'listp (mapcar 'cadr (ssnamex ss)))
   (setq elist (entget ename))
   (entmod (subst (reverse (cons z (cdr (reverse (assoc '10 elist))))) (assoc '10 elist) elist))
  ); foreach
 ); if
 (vla-endUndoMark adoc)
 (vlax-release-object adoc)
 (princ)
); c:coz
CADaSchtroumpf
If you stretch your line to the tip of your solid, you can insert a field in the default attribute value that will retrieve the Z of your starting point of the line.
On insert if a Z is provided (.XY then Z keyboard value or snap to an entity) the attribute will be updated
Field value:
%<\AcObjProp.16.2 Object(%<\_ObjId 1405295569824>%,1).StartPoint \f "%lu6%pt4">%
jlootsCB78E
The block already have a x y z position. I need to update the attribute value of "UTILITY_INVERT" in the data field.
So I need to take the Z from the block position and update the field.
jlootsCB78E
If you look at the Z it is at 1250 so i want to have the :UTILITY_INVERT" updated to I.L.=1250.000 and if posseble remove 110mm from the hight to give me the new invert of I.L.=1249.89 is where I want to land up.
Thanks for the help
Moshe-A
@jlootsCB78E ,
fixed
; common z value
   (setq ask def)
   (setq def ask)
 ); askdist
 ; here start c:coz
 (if (and
      ; (setvar "userr5" (setq z (askdist (getvar "userr5"))))
 ; (entmod (subst (reverse (cons z (cdr (reverse (assoc '10 elist))))) (assoc '10 elist) elist))
   (setPropertyvalue ename "utility_invert" (strcat "I.L.=" (rtos (last (assoc '10 (entget ename))) 2 2)))
  ); foreach
 ); if
 (princ)
); c:coz
jlootsCB78E
Thank you.
Is there a way to auto deduct the UTILITY_HEIGHT from the value as well?
Will be apreciated
CADaSchtroumpf
Alway with the fields...
Copy-paste directly in command line
((lambda ( / ss n ent obj)
  (setq ss (ssget "_X" '((0 . "INSERT") (2 . "Utl_Arrow Bottom Left"))))
  (cond
    (ss
      (setvar 'cmdecho 0)
      (repeat (setq n (sslength ss))
        (setq
          ent (ssname ss (setq n (1- n)))
          obj (vlax-ename->vla-object ent)
        (vla-put-TextString (cadr (vlax-invoke obj 'GetAttributes))
          (strcat
            "I.L.="
            "%<\\AcExpr ("
            "%<\\AcObjProp Object(%<\\_ObjId "
            (itoa (vla-get-ObjectID obj))
            ">%).InsertionPoint \\f \"%pt4\">%"
            "-(0.001*"
            (itoa (vla-get-ObjectID (last (vlax-invoke obj 'GetAttributes))))
            ">%).TextString>%)) \\f \"%lu2%pr2\">%"
        (vl-cmdf "_.updatefield" ent "")
      (setvar 'cmdecho 1)
  (prin1)
jlootsCB78E
Thank
This helps a million
