I need to select Centerline Alignment only ( filter ) from selection?
y.awwad
y.awwad
I select one Alignment and then select similar but all alignments selected
(ssget (list (cons 0 "AECC_ALIGNMENT")))
I need to filter the selection to (Centerline Alignment only )
hosneyalaa
@y.awwad
PLS
Example drawing
TRY
(princ "\nSelect alignment: ")
(setq ssalign (ssget ":S" '((0 . "AECC_ALIGNMENT"))))
y.awwad
@hosneyalaa
I already selected all alignments .. but I need to filter the selection to (Centerline Alignments only )
Not offset alignments
Not curb return alignments
hosneyalaa
FILTER BY NAME
y.awwad
Filter Civil 3D Alignment By Type
Same as filtering Line (ssget (list (cons 0 "LINE"))) or (ssget (list (cons 0 "POLYLINE"))) or (ssget (list (cons 0 "LWPOLYLINE"))) .. Filter by type no names
hosneyalaa
CAN YOU  Easily BU CIVIL API .NET  NOT BY COM CIVIL API
https://help.autodesk.com/view/CIV3D/2025/ENU/?guid=2ecbe421-4c08-cbde-d078-56a9f03b93f9
y.awwad
