plz help me
i need lisp or solution to get points of (center) lines or polyliens
plz check attache file
plz help me
check this.
(defun c:point_middle_line nil
(foreach line_object (mapcar 'vlax-ename->vla-object (vl-remove-if 'listp (mapcar 'cadr (ssnamex (ssget '((0 . "line")))))))
(vla-addpoint (vla-get-block (vla-get-activelayout (vla-get-activedocument (vlax-get-acad-object))))
(vlax-3d-point (polar (vlax-get line_object 'startpoint)
(angle (vlax-get line_object 'startpoint) (vlax-get line_object 'endpoint))
(* 0.5 (distance (vlax-get line_object 'startpoint) (vlax-get line_object 'endpoint)))
(defun C:PLM (/ ss n lin); = Points at Line Midpoints
(if (setq ss (ssget '((0 . "LINE"))))
(repeat (setq n (sslength ss))
(setq lin (ssname ss (setq n (1- n))))
(command "_.point" "_non"
(mapcar '/
(mapcar '+ (vlax-curve-getStartPoint lin) (vlax-curve-getEndPoint lin))
'(2 2 2)
); mapcar
); command
); repeat
); if
(prin1)
