i need help with this chainage lisp
marchand_desclave
marchand_desclave
Hello I need help to modify this list so that the chaining is oriented with the polyline. I would also like to be able to add a prefix like CH: in front here are 2 images to illustrate the current problem of this lisp
the problem : https://imgur.com/PN5tZ0q
the result i am looking for : https://imgur.com/zU2n23p
;;DESIGNED BY ALEEM AHMAD KHAN
;;EPHED NESPAK, JUNE 24 2003
;;EDITED BY MIL, 20/05/2004
(DEFUN C:RDS()
(RDInput1)
(RDSA)
(defun C:RDS1()
(RDSA)
(defun RDSA ()
(setq cmdold (getvar "cmdecho"))
(setvar "cmdecho" 0)
(setq osmold (getvar "osmode"))
(setvar "osmode" 0)
(princ) (terpri)
(setq sst nil)
(while (= sst nil)
(setq sst (entsel "\nSelect Polyline/ Line for Marking RDs"))
(setq RD (+ RD rdi)) ; First Value
(COMMAND "MEASURE" sst "B" rdmB "" mdi)
(COMMAND "MEASURE" sst "B" "RD" "" rdii)
(setq SSET (ssget "P"))
(setq COUNT 0)
(while (< COUNT (sslength SSET))
(setq A1 (ssname SSET count))
(setq A2 (entget A1))
(setq A3 (cdr (assoc 0 A2)))
(if (= A3 "INSERT")
(progn
(setq A4 (assoc 10 A2))
(setq A5 (cdr A4))
(command "EXPLODE" a1)
(SETQ X1 (ENTGET(ENTLAST)))
(SETQ X2 (ASSOC 1 X1))
(SETQ X3 (CDR X2))
(SETQ RD5 (RTOS RD 2 0))
;(setq B1 (strcat "(" X3 ")"))
;(setq B1 (strcat RD5 "+000"))
(setq RDtxt RD5)
(text1)
(setq B1 RDtext)
(setq B2 (cons 1 B1))
;(setq A2 (subst B2 A4 A2))
(setq A2 (subst B2 X2 X1))
;(command "DDEDIT" "L" "")
(entmod A2)
(SETQ RD5 (ATOF RD5))
(SETQ RD (+ RD5 rdi))
);Progn
);if
(setq count (+ 1 count))
);while
(setvar "cmdecho" cmdold)
(setvar "osmode" osmold)
(terpri)
(princ (strcat " RD = " (rtos rd 2 0))) (terpri)
);defun
(defun text1 (/ abs2 rem1)
(if (and (= (strlen RDtxt) 1) (= RDtxt "0")) (Progn
(setq RDtxt "0000"))
(progn
(if (and (> (strlen RDtxt) 1) (<= (strlen RDtxt) 3))
(setq RDtxt (strcat "0" RDtxt)))
(setq abs2 (substr RDtxt 1 (- (strlen RDtxt) 3)))
(setq rem1 (substr RDtxt (+ (strlen abs2) 1)))
(setq RDtext (strcat abs2 "+" rem1))
(defun c:RDInput ()
(RDInput1)
(defun c:RD ()
(RD1)
(defun c:RDI()
(RDI1)
(defun c:RDM()
(RDM1)
(defun c:RDMB()
(RDMB1)
(defun c:SF()
(SF1)
(defun RDInput1 ()
(SF1) ; Scale Factor
(RD1) ; RD # and block
(RDblk)
(RDI1) ; RD interval
(RDM1) ; RD marker Interval
(RDMB1) ; RD marker block name
(defun RD1 (/ RD1)
(if (= RD nil) (setq RD 0))
(setq RD1 (getreal (strcat "\nStart RD # [" (rtos RD 2 0) "] :")))
(if (/= RD1 nil) (setq RD RD1))
(princ (strcat "RD = " (rtos rd 2 0))) (terpri)
(defun RDI1(/ rdiA)
(if (= rdi nil) (setq rdi 250))
(setq rdiA (getreal (strcat "\nRD # Interval [" (rtos RDi 2 0) "] :")))
(if (/= rdiA nil) (setq rdi rdiA))
(princ (strcat "RD Intr = " (rtos rdi 2 0))) (terpri)
(setq rdii (* rdi ssf))
(defun RDM1(/ mdA)
(if (= md nil) (setq md 250))
(setq mdA (getreal (strcat "\nRD Marker Distance [" (rtos md 2 0) "] :" )))
(if (/= mdA nil) (setq md mdA))
(if (> md rdi) (setq md rdi))
(princ (strcat "RD marker Dist = " (rtos md 2 0))) (terpri)
(setq mdi (* md ssf))
(defun RDMB1()
(if (= rdmB nil) (setq rdmB " "))
(setq rdmB (getstring (strcat "\nBranch/ Distributary Name for RD Marking [" rdmB "]:")))
(while (equal rdmB "")
(setq rdmB (getstring (strcat "\nBranch/ Distributary Name for RD Marking [" rdmB "]:"))))
(princ (strcat "RD marker Blk = " rdmB))
(RDmarker) ; RD marker Block
(defun SF1(/ ssf1)
(if (= ssf nil) (setq ssf 1.0))
(setq ssf1 (getreal (strcat "\nSheet Scale Factor [" (rtos ssf 2 😎 "] :")))
(if (/= ssf1 nil) (setq ssf ssf1))
(princ (strcat "Sheet Scale Factor = " (rtos ssf 2 8))) (terpri)
(defun RDblk(/ sl curlyr osmold list1)
(setvar "osmode" 0)
;(setq curLyr (getvar "clayer"))
;(command "layer" "thaw" "0" "set" "0" "on" "0" "")
(if (equal (tblsearch "block" "RD") nil) (progn
(command "zoom" "e")
(command "style" "ghc" "Arial" "0.0" "1.0" "0" "N" "N")
(command "color" "green")
(command "TEXT" "S" "ghc" "J" "ML" "0,0" "10.0" "90" "0+000")
;(setq list1 (list (cons 0 "TEXT") (cons 40 10.0) (cons 1 "0+000")))
(setq list1 (list (cons 0 "TEXT")(cons 1 "0+000")))
(setq sl (ssget "l" list1))
(command "block" "RD" "0,-10" sl "")
; (command "erase" sl "")
;(command "layer" "set" curlyr "on" curlyr "")
(command "zoom" "p")
(defun RDmarker(/ sl1 osmold list1)
(setvar "osmode" 0)
(if (equal (tblsearch "block" rdmB) nil) (progn
(command "color" "bylayer")
(command "line" "0,0" "0,5" "")
(setq list1 (list (cons 0 "LINE") (cons 10 (list 0.0 0.0 0.0)) (cons 11 (list 0.0 5.0 0.0))))
(setq sl1 (ssget "l" list1))
(command "block" rdmB "0,0" sl1 "")
(princ "\nStart Command with:- <RDS> ")
(princ)
Chainage Mark on Pline.LSP
Affichage de Chainage Mark on Pline.LSP en cours.
Sea-Haven
For me not worth the time trying to change it,  I have like 3 different chainage.lsp just google and try a couple of the others out there and get the one that meets your needs. Ch xxx or CH x+xxxx are available.
john.uhden
@marchand_desclave
Please don't take any offense, but that seems to be an antique way of going about it.
You have at hand a number of vlax-curve-* functions to use, the primary one of which is to find points at distances along the curve.  I don't mean just an arc segment; I mean the entire polyline.  So, f'rinstance, in one shot you could add tic marks and label the chainage, even tangent to the point on the curve, and with a little of our help the label could be readable and even account for any viewtwist you might use.
Would you like to learn how to do that?  I ask because I am one of the many around here who wants to help people help themselves and to be able to their own hunting and gathering and inventing and manufacturing.  I could also suggest that you pay for Civil 3D, which will do it all for you, but it is typical that you or your company don't have the means to afford it.  Maybe you don't need to generate surface models and contours or automated profiles and cross sections, or do earthwork analyses, or automatically generate parcel bearings and distances, or import GIS data from one projection into another.  Or maybe you would like to.
i don't know, but a good number of very smart and experienced people are here for you to help yourself, if you are willing to learn.  It's not like nuclear physics or something dauntingly theoretical.  It's just a bag of tools that you learn to use with practice.  I can see that you already have some comfort with some of the basic tools, but there is so much more that will make your work easier, shorter, and more powerful.
AND we will all have FUN doing it.
John F. Uhden
marchand_desclave
thank you, I appreciate your recommendation, and yes I learned civl 3D at school and I know what a steroid booster it is (the surfaces with all the colors of the rainbow) with all the extra features. but i don't currently work in civil engineering so my company doesn't have a civil 3d license but only autocad one and i feel a bit nostalgic for all the extra function i learned to the school of what civil 3D was doing, for the moment I am trying to learn more in the immense universe of the most useful LISPs that the greatest programmers have been able to design
yashavantnez
Community Visitor
Community Visitor
What is Command for draw chainage
Sea-Haven
If you have a lisp and load it and nothing happens then look at the code with notepad and look for the (defun C:, in the chainage lisp its (defun C:D10, this means just type the word D10 on command line. The word following the C: is the command to use, another method so it runs on load is to put (c:D10) as last line in the lisp.
