I need a Lisp to copy a number and paste in another object
mmprakash90
Message 1 of 21
mmprakash90
Hi All,
I have a scenario where I need a Lisp program to copy and paste within same DWG
In a DWG I have a number for
EX :123456
And another object like ADD=XXXXXX
Now , I want that 123456 in the place of XXXXXX like ADD= 123456 in just two three clicks
Need your help
Replies (20)
Message 2 of 21
Kent1Cooper
You don't really "have a number," but some kind of object whose text content is numerical, and another whose text content is partly numerical.  What are the objects?  Text?  Mtext?  Block Attributes?  Dimension text override?  Not always the same kind(s)?  Are they always both the same kind of object as each other?  Is the first one really always only numbers, or might it have other characters like the second one?  Is the format of the second one reliably the same [for example, with the numerical part always at the end, and no numbers before that]?  Etc., etc.
A small sample drawing could help, including as many scenarios as you would encounter.
Kent Cooper, AIA
Message 3 of 21
Moshe-A
@mmprakash90  hi,
check this cpy&pst command
enjoy
Moshe
(defun c:cpy&pst (/ _digits ; local function
		    ss0 ss1 txt0 txt1 txt2 sor0 ename elist p)
 ; anonymous function
 (setq _str->digits
	(lambda (s)
	  (apply
	    'strcat
	    (vl-remove-if
	      'not
	      (mapcar
		(function
		  (lambda (n)
		    (if (and (>= n 48) (<= n 57)) (chr n))
		  ); lambda
		); function
		(vl-string->list s)
	      ); mapcar
	    ); vl-remove-if
	  ); apply
	); lambda
 ); setq
 (setvar "cmdecho" 0)
 (command "._undo" "_begin")
 (if (and
       (not (prompt "\nPick source text..."))
       (setq ss0 (ssget ":s:e+." '((0 . "text,mtext"))))
       (not (prompt "\nSelect target text(s)..."))
       (setq ss1 (ssget '((0 . "text,mtext"))))
  (progn
   (setq txt0 (cdr (assoc '1 (entget (ssname ss0 0)))))
   (setq sor0 (_str->digits txt0))
   (foreach ename (vl-remove-if 'listp (mapcar 'cadr (ssnamex ss1)))
    (setq elist (entget ename))
    (setq txt1 (cdr (assoc '1 elist)))
    (if (setq p (vl-string-position (ascii "=") txt1 0 t))
     (progn
      (setq txt2 (strcat (substr txt1 1 (1+ p)) sor0))
      (entmod (subst (cons '1 txt2) (assoc '1 elist) elist))
     ); progn
    ); if
   ); foreach
  ); progn
 ); if
 (command "._undo" "_end")
 (setvar "cmdecho" 1)
 (princ)
Message 4 of 21
mmprakash90
 The above objects are constant,
One is numeric which needs to be copied and pasted in alphanumeric ADD=XXXXXX or at the place of only XXXXXX.When I click/select on number it should pick /copy that number and when I click on Other object it should paste that number result as shown in pic
Message 5 of 21
Kent1Cooper
The remaining crucial question:  object type(s)?
Kent Cooper, AIA
Message 6 of 21
Sea-Haven
I did no code
Dbl Click 123456, ctrl+a, ctrl+c
esc
Dbl click text, select xxxx, Ctrl+v
Alldone
Message 7 of 21
mmprakash90
They are not blocks ,just Texts alphanumeric Texts
Message 8 of 21
mmprakash90
We have to do it for 10k addresses daily
Message 9 of 21
Moshe-A
@mmprakash90 ,
have read message #3?
Message 10 of 21
Kent1Cooper
@mmprakash90 wrote:
 The above objects are constant, ....
If "constant" means really constant, that is, the source Text is always six and only six numerical-only digits, and the target object always ends with six capital X's, whether or not there is anything more before them or how much is before them, and if they're both Text objects specifically, then this seems to work:
(defun C:TEST (/ source str1 target str2)
  (if
    (and
      (setq source (car (entsel "\nNumerical source Text object: ")))
      (wcmatch (setq str1 (getpropertyvalue source "TextString")) "*######")
      (not (redraw source 3)); highlight [(not) because it returns nil]
      (setq target (car (entsel "\nText object with XXXXXX to be replaced: ")))
      (wcmatch (setq str2 (getpropertyvalue target "TextString")) "*XXXXXX")
    ); and
    (progn ; then
      (redraw source 4); un-highlight
      (setpropertyvalue target "TextString" (vl-string-subst str1 "XXXXXX" str2))
    ); progn
    (prompt "\nInappropriate object selected.")
  ); if
  (prin1)
But that's in simplest terms.  It could be made more sophisticated, to overcome certain possibilities.  For example, it could be made to allow for Mtext [different property name for the contents].  If a target ends with more than six capital X's in a row, the first six of them will be the ones replaced, not the last six.  It currently allows selection of Text on locked Layers, but could prevent that at least for the target [it wouldn't matter for the source, unless you want that removed].  And probably some other things....
Kent Cooper, AIA
Message 11 of 21
komondormrex
another one goes
(defun c:replace_XXXXXX ( / num_text num_string target_string target_dxf)
  (while (setq num_text (car (entsel "\nPick text with number to get from: ")))
	 (setq num_string (cdr (assoc 1 (entget num_text))))
	 (if (wcmatch (setq target_string (cdr (assoc 1 (setq target_dxf (entget (car (entsel (strcat "\nPick text to replace \"XXXXXX\" with \"" num_string "\": "))))))))
		       "*ADD=XXXXXX*"
	     (entmod (subst (cons 1 (vl-string-subst (strcat "ADD=" num_string) "ADD=XXXXXX" target_string)) (assoc 1 target_dxf) target_dxf))
	 (princ)
Message 12 of 21
ec-cad
Try this Lisp. Function call is SREP. Posted into another post just today.
It is a search-replace type process, will change partial string values for Text, Mtext or Attribute values
within Blocks. Drag / drop the Lisp file into your Acad open drawing type SREP at Command Line,
then Type in 123456, and the replacement # or string e.g 456XXX and it will change them all.
If you have 'unique' numbers for those addresses, it probably won't be of use for that.
But is a handy tool for general use.
ECCAD
Message 13 of 21
mmprakash90
This is working fine, But I have below scenario like
Add=XXXXXX
PB=XXXXXX
TP=XXXXXX
And sometimes only
XXXXXX
These X's only should be replaced with numbers like 123456 or what ever number and resulting below
Add = 123456
PB = 123456
TP = 123456
And sometimes only
123456
PM
Message 14 of 21
komondormrex
then maybe this one
		       "*XXXXXX*"
	     (entmod (subst (cons 1 (vl-string-subst num_string "XXXXXX" target_string)) (assoc 1 target_dxf) target_dxf))
	 (princ)
Message 15 of 21
Sea-Haven
If its just "XXXXXX" then why not use FIND.
If needed could get the "123456" from text, copy to clipboard and paste into the Find command.
Message 16 of 21
mmprakash90
Yes ,it works better
Message 17 of 21
mmprakash90
Yes its working, But its only working for 6 digits what if the digits very, from 6 to 5 or I may have to replace 7 digits or 4 digits.How to do at that time
Message 18 of 21
komondormrex
if you happened to have full autocad with et installed you may try the following adaptation of the code
(defun c:replace_X-X ( / num_text num_string start_x_pos end_x_pos target_string target_dxf)
	 		(while (null (setq start_x_pos (acet-str-find "[xX]+"
	 			 								  		   (setq target_string
	 											  										(entget (car (entsel (strcat "\nPick text to replace \"X...X\" with \""
	 											  																	  num_string
	 											  		   ) t t
	 							end_x_pos start_x_pos
	 				 					num_string
	 				 					(substr target_string
	 				 							start_x_pos
	 											(progn
	 												  (while (or (= "X" (substr target_string (setq end_x_pos (1+ end_x_pos)) 1))
	 															 (= "x" (substr target_string end_x_pos 1))
	 												  (- end_x_pos start_x_pos)
	 									target_string
	 						target_dxf
	 (princ)
Message 19 of 21
mmprakash90
Is it possible for Multileader text /callot as shown in pic, it should paste by suffix ID=123456
 Pls help with this sir
Message 20 of 21
mmprakash90
@komondormrex Its working fine for normal text, if we have Multileader texts or call outs its not working .Can you please help with similar code for multileader texts. I need to replace XXXXXX in below text and result the ID=123456(or some other number)
