I need a LISP that creates multiple boundary polylines around each room
Message 1 of 10
Hi All,
So i need a lisp routine created which allows me to select an entire drawing and it create polylines around every separate boundary of the selection on the current layer.
basically every drawing i receive, i need to polyline each individual room, open space area, corridor etc. it is very time consuming and was wondering if anyone smart enough can create a quicker way?
Replies (9)
Message 2 of 10
ArchD
If you isolate a layer, would LINEWORKSHRINKWRAP work for what you need?
Archie Dodge
Applications Expert - Infrastructure Solutions Division
IMAGINiT Technologies
Message 3 of 10
comes up with unknown command? is it an app i need to load in?
Message 4 of 10
ArchD
My apologies, apparently that is a Civil 3D specific command.
Archie Dodge
Message 5 of 10
ArchD
http://www.lee-mac.com/outlineobjects.html
Give this a shot. This guy makes some amazing lisps. Browse his site, you might find some to help you out on daily tasks other than this particular situation.
Archie Dodge
Message 6 of 10
pendean
Community Legend
Community Legend
Are you trying to create boundaries on the fly in a DWG file for a 3rd party FM software? Or Lease SF Calcs?
What exact variant and year version of AutoCAD are you using? Plain AutoCAD doesn't know what a "room" is for example from an exploded Toilet block. No freebie LISP is going to do it correctly either.
Message 7 of 10
Kent1Cooper
@Anonymous wrote:
... to select an entire drawing and it create polylines around every separate boundary of the selection on the current layer.  basically every drawing i receive, i need to polyline each individual room, open space area, corridor etc. ....
I'm picturing that in order to do this in something like a Floor Plan, there would need to be Lines [or Polylines, or whatever] representing the wall surfaces of the rooms/areas/corridors, and  Lines crossing door and window openings [maybe window sill  Lines would do if you don't draw projecting  sills].  Presumably such things would not  all be on "the current layer," nor on the same Layer as each other, whether current or not.  So I imagine having a wall Layer and a door/window-head Layer [also useful for a Reflected Ceiling Plan], and using something like LAYISO to have only those Layers on [not doors with swings, not plumbing fixtures, not room names, etc.], and then there might be a way to approach automating a collective Boundary command.  What's your Layering scheme like?  Can you post a simplified sample drawing?
Kent Cooper, AIA
Message 8 of 10
john.uhden
He may need to draw some lines to "close" doors and windows, but that's better than tracing around each room.
One idea that just occurred to me is that maybe there's a label in each room on a certain layer that can be used as the pick point for the automated BOUNDARY commands.
John F. Uhden
Message 9 of 10
ahmad_ashfaq
Community Visitor
Community Visitor
Thanks, helpful
Message 10 of 10
Sea-Haven
My money is on @john.uhden method just pick internal point and a boundary is made, I use Bpoly. yes if have areas labelled then this is example code need a real dwg.
Note the double boundary when a internal point has an island.
(defun c:roombdy ( / obj lay pt)
(command "-layer" "M" "Dummy" "c" 1 "" "")
(setq obj (vlax-ename->vla-object (car (entsel "\nPick room text for layer "))))
(setq lay (vlax-get obj 'Layer))
(setq ss (ssget (list (cons 0 "*TEXT")(Cons 8 lay))))
(repeat (setq x (sslength ss))
  (setq obj (vlax-ename->vla-object (ssname ss (setq x (- x 1)))))
  (setq pt (vlax-get obj 'insertionpoint))
  (command "bpoly" pt "")
(princ)
(c:roombdy)
