I made my implement of vl-remove-if,and some much weird things happened!
ivanovsky
ivanovsky
Some guy's cad system has no vl-* functions,and I made some for him.most of implements I made are work well,but some of them are not.
Here is my implement.
my vl-remove-if,the func 1, works well.
(defun xg-remove-if  (fn lst)
  (cond ((null lst) nil)
        (t
         (if (apply fn (list (car lst)))
           (xg-remove-if fn (cdr lst))
           (cons (car lst) (xg-remove-if fn (cdr lst)))))))
and this is my vl-remove,the fun 2,works well too.
(defun xg-remove (elem lst) (xg-remove-if '(lambda (x) (equal elem x)) lst))
 and then,I made my vl-remove-if-not,the fun 3, I would like it to work too,but it doesn't work!
(defun xg-remove-if-not  (fn lst)
  (xg-remove-if '(lambda (x) (not (apply fn (list x)))) lst))
I run it,the visual ide run out of it's memory and brokedown!
Why? I'm totally confused,I have no idea what happened.
Therefore, I've tried another way, I made my 2nd version of vl-remove-if-not,the fun 4, and it works!
(defun xg-remove-if-not2  (fn lst)
  (vl-remove-if '(lambda (x) (not (apply fn (list x)))) lst))
Anyway, I have to deliver my functions to my guy,I made my 3rd version of vl-remove-if-not, the ugly one, the fun 5, not elegant at all.Whatever,it works well.
        (t
         (if (not (apply fn (list (car lst))))
           (xg-remove-if-not fn (cdr lst))
           (cons (car lst) (xg-remove-if-not fn (cdr lst)))))))
I wonder to know whether there is kind of bug in visual ide, because I don't find out bugs in my functions.
I rewrote those functions in dr racket, and all of them work well.
Is there anyone who could help me know what happened? Thank you for reading.
  • Lisp
ВeekeeCZ
Here's the fix.
(defun xg-remove-if-not  (fn1 lst)
  (xg-remove-if '(lambda (x) (not (apply fn1 (list x)))) lst))
ivanovsky
OMG! AMAZING! AWSOME!
Thank you very much, Mr/Mz Z9E3zK5E!
Is this some kind of black magic?
Why must I change the name of 1st argument?
It confused me so much!
ВeekeeCZ
See THIS screencast from debugging this:
  (print fn)  ; should be lambda
  (print lst) ; should be '(1 0 1 0)
        (t
			     (progn (print fn) fn) ; should be lambda
			     (cdr lst)))))))
  (print fn)  ; should be zerop
  (xg-remove-if (function (lambda (x) (not (apply (progn (print fn) fn) ; should be zerop
						  (list x))))) lst))
(defun c:Test ()
  (xg-remove-if-not 'zerop '(1 0 1 0)))
Simply the fn arguments are in conflict.
fn from xg-remove-if-not (= zerop) is a global to the xg-remove-if func
but it's overwritten by xg-remove-if's argument fn (= lambda) argument.
These names have to differ.
Another question is whether lst arg should differ too. I would rather rename it too even it does no harm in this case since the overwriting value is the same as the original.
HTH
ivanovsky
Thank you very much, your anwsers are very concrete, I think I've understood what you said.Thanks again.
