i created a cleanup lisp with chatgpt
jwen_lye
Observer Observer
Message 1 of 9
jwen_lye
Observer
Observer
spend some time learn lisp with chatgpt and we finally outcome a cleaning lisp for architect drawing,
and i am sharing here because i learn a lot from forum, and i also hope to get advice, upgrade and improvement for increase the work efficiency for this lisp.
(especially PHASE 5 – FAST DUPLICATE REMOVAL, _overkill all will stuck me for several hours to file collapse)
**Some key word replaced by "MAGIC WORD" due to privacy and confidential, so please reset them if you want to try it out.
;;; HOUSEKEEPING.lsp
;;; PHASE 0 – Environment preparation
(defun HK:P0-ENV ( / )
(princ "\n[Phase 0] Environment preparation...")
;; Safe system variables
(setvar "CMDECHO" 1)
(setvar "PICKFIRST" 1)
(setvar "EXPERT" 5)
;; Ensure Model Space
(if (= (getvar "TILEMODE") 0)
(command "._TILEMODE" 1)
;; Clear active command stack
(while (> (getvar "CMDACTIVE") 0) (command ""))
;; Force safe current layer
(setvar "CLAYER" "0")
(princ "\n[Phase 0] Environment locked, current layer set to 0.")
(princ)
;;; PHASE 1 – View, UCS, Units
(defun HK:P1-VIEW-UCS-UNITS ( / )
(princ "\n[Phase 1] Setting view, UCS, and units...")
;; PLAN to World
(command "._PLAN" "_WORLD")
;; UCS to World
(command "._UCS" "_WORLD")
;; Units (decimal, mm)
(setvar "LUNITS" 2)
(setvar "LUPREC" 8)
(setvar "AUNITS" 0)
(setvar "AUPREC" 8)
(setvar "INSUNITS" 4)
(princ "\n[Phase 1] View=World, UCS=World, Units=mm locked.")
(princ)
;;; PHASE 2A – Layer reset & allow explode
(defun HK:LAYER-RESET-ALL ( / )
(princ "\n[Phase 2A] Resetting layers (thaw/unlock/on)...")
(command "._-LAYER" "_T" "*" "")
(command "._-LAYER" "_U" "*" "")
(command "._-LAYER" "_ON" "*" "")
(princ "\n[Phase 2A] All layers thawed, unlocked, and ON.")
(princ)
(defun HK:BLOCK-ALLOW-EXPLODE ( / doc blocks)
(vl-load-com)
(setq doc (vla-get-ActiveDocument (vlax-get-acad-object)))
(setq blocks (vla-get-Blocks doc))
(vlax-for blk blocks
(if (and (= (vla-get-IsLayout blk) :vlax-false)
(= (vla-get-IsXref blk) :vlax-false))
(vl-catch-all-apply 'vla-put-Explodable (list blk :vlax-true))
(princ "\nAll blocks set to allow exploding.")
(princ)
(defun HK:PROTECT-LAYERS (/ doc lays lay desc name)
(vl-load-com)
(setq lays (vla-get-Layers doc))
(princ "\n[Phase 2A] Protecting layers...")
(vlax-for lay lays
(setq name (vla-get-Name lay))
(setq desc (vla-get-Description lay))
(if (and desc
(wcmatch (strcase desc) "*MAGIC WORD*"))
(progn
(vla-put-Lock lay :vlax-true)
(vla-put-Freeze lay :vlax-true)
(vla-put-LayerOn lay :vlax-true)
(princ (strcat "\nProtected: " name))
(princ)
(defun HK:P2A-PREPARE (/)
(princ "\n[Phase 2A] Preparing layers and block permissions...")
(HK:LAYER-RESET-ALL)
;; Friendly fire protection
(HK:PROTECT-LAYERS)
(HK:BLOCK-ALLOW-EXPLODE)
(princ "\n[Phase 2A] Ready.")
(princ)
;;; PHASE 2A – Lock 50% layers
(defun HK:P2A-LOCK50 (/ lay layTable count totalLayers halfLayers)
(vl-load-com)
(setq layTable (vla-get-Layers (vla-get-ActiveDocument (vlax-get-acad-object))))
(setq count 0)
(setq totalLayers (vla-get-Count layTable))
(setq halfLayers (fix (/ totalLayers 2.0)))
(vlax-for lay layTable
(if (and (/= (vla-get-Name lay) "0")
(/= (vla-get-Name lay) (getvar "CLAYER"))
(< count halfLayers))
(progn
(setq count (1+ count))
(princ (strcat "\n[P2A-LOCK50] " (itoa count) " layers locked."))
(princ)
;;; PHASE 2B – Explode blocks automatically (safe with attributes)
(defun HK:ATTR->TEXT (blkEnt / att data)
;; Convert block attributes to TEXT
(setq att (entnext blkEnt))
(while (and att (= (cdr (assoc 0 (entget att))) "ATTRIB"))
(setq data (entget att))
(entmake
(list
'(0 . "TEXT")
(cons 10 (cdr (assoc 10 data)))
(cons 40 (cdr (assoc 40 data)))
(cons 1 (cdr (assoc 1 data)))
(cons 7 (cdr (assoc 7 data)))
(cons 50 (cdr (assoc 50 data)))
(cons 8 (cdr (assoc 8 data)))
(setq att (entnext att))
(defun HK:EXPLODE-BLOCK-REF (ent / obj result)
(vl-load-com)
(if (and ent (entget ent))
(progn
(setq obj (vlax-ename->vla-object ent))
(setq result (vl-catch-all-apply 'vlax-invoke (list obj 'Explode)))
(if (not (vl-catch-all-error-p result))
(vla-delete obj)
(defun HK:P2B-BLOCK-EXPLODE (/ ss i ent)
(vl-load-com)
(princ "\n[P2B] Controlled explode...")
;; ONLY ATTR->TEXT ONCE
(setq ss (ssget "_X" '((0 . "INSERT"))))
(if ss
(progn
(setq i 0)
(while (< i (sslength ss))
(setq ent (ssname ss i))
(HK:ATTR->TEXT ent)
(setq i (1+ i))
;; MULTIPLE explode
(repeat 5
(if ss
(progn
(setq i 0)
(HK:EXPLODE-BLOCK-REF ent)
(setq i (1+ i))
(princ "\n[P2B] Done.")
;;; PHASE 2C – Unlock all layers
(defun HK:P2C-LAYER-RESET (/)
(princ "\n[P2C] Resetting layers...")
;; Friendly fire protection again
(HK:PROTECT-LAYERS)
(princ "\n[P2C] Layers reset and INF layers protected.")
(princ)
;;; PHASE 2D – AUDIT
(defun HK:P2D-AUDIT (/)
(vl-cmdf "_AUDIT" "_Y")
(princ "\n[P2D] AUDIT complete, errors fixed.")
(princ)
;;; PHASE 3 – Pre-clean (safe)
(defun HK:ERASE-BY-TYPE (type / ss)
(setq ss (ssget "_X" (list (cons 0 type))))
(if ss (command "_.ERASE" ss ""))
(defun HK:ERASE-SOLID-HATCH (/ ss i ent)
(setq ss (ssget "_X" '((0 . "HATCH"))))
(if ss
(progn
(setq i 0)
(HK:SAFE-MTEXT-CLEAN ent)
(setq i (1+ i))
(defun HK:ERASE-EMPTY-BLOCKS (/ ss i en ed blk)
(if ss
(progn
(setq i 0)
(setq en (ssname ss i)
ed (entget en)
blk (tblsearch "BLOCK" (cdr (assoc 2 ed))))
(if (and blk
(= 0 (logand 1 (cdr (assoc 70 blk))))
(null (cdr (assoc -2 blk)))
(command "_.ERASE" en "")
(setq i (1+ i))
(defun HK:SAFE-MTEXT-CLEAN (ent / data txt)
(if (and ent (setq data (entget ent)))
(progn
(setq txt (cdr (assoc 1 data)))
(if txt
(progn
;; Strip color codes
(setq txt (StripMTextColor txt))
;; Update entity with cleaned text
(entmod (subst (cons 1 txt) (assoc 1 data) data))
;; Delete if text is empty
(if (or (null txt) (= txt ""))
(entdel ent)
(defun HK:CLEAN-REGAPP ( / )
(princ "\nCleaning RegApp records...")
(command "._-PURGE" "_R" "*" "_N")
(princ "\nRegApp cleanup completed.")
(defun HK:P3-ERASE (/ ss i ent)
(princ "\n[Phase 3] Pre-clean started...")
;; Safe MTEXT cleanup
(setq ss (ssget "_X" '((0 . "MTEXT"))))
;; Other junk
(HK:ERASE-BY-TYPE "WIPEOUT")
(HK:ERASE-BY-TYPE "POINT")
(HK:ERASE-BY-TYPE "OLE2FRAME")
(HK:ERASE-BY-TYPE "REGION")
(HK:ERASE-BY-TYPE "ATTDEF")
(HK:ERASE-SOLID-HATCH)
(HK:ERASE-EMPTY-BLOCKS)
;; REGAPP purge
(HK:CLEAN-REGAPP)
(princ "\n[Phase 3] Pre-clean completed.")
(princ)
;;; PHASE 4 – Flatten + Elevation Reset
(defun HK:P4-ZMOVE (/ ss)
(princ "\n[Phase 4] Flattening and Elevation Reset...")
(setq ss (ssget "_X"))
(if ss
(repeat 2
(command "._CHANGE" ss "" "_Properties" "_Elevation" "0" "")
(command "_FLATTEN" "_ALL" "")
(command "_AUDIT" "_Y" "_REGEN")
(princ "\n[Phase 4] Elevation reset, flatten, audit done.")
(princ)
;;; PHASE 5 – FAST DUPLICATE REMOVAL
;;; Supports LINE, ARC, CIRCLE, LWPOLYLINE
(defun HK:SAFE-NUM (v) (if (numberp v) v 0.0))
(defun HK:SAFE-PT (p) (if (and p (= (length p) 3)) p '(0 0 0)))
(defun HK:ROUND (val prec) (if (numberp val) (/ (float (fix (* val prec))) prec) 0.0))
(defun HK:PT-KEY (pt prec)
(if (and pt (= (length pt) 3))
(strcat (rtos (HK:ROUND (car pt) prec) 2 6) ","
(rtos (HK:ROUND (cadr pt) prec) 2 6) ","
(rtos (HK:ROUND (caddr pt) prec) 2 6))
"0,0,0")
(defun HK:LINE-KEY (edata prec / p1 p2 tmp)
(setq p1 (HK:SAFE-PT (cdr (assoc 10 edata))))
(setq p2 (HK:SAFE-PT (cdr (assoc 11 edata))))
(if (> (car p1) (car p2))
(setq tmp p1 p1 p2 p2 tmp))
(strcat "LINE|" (HK:PT-KEY p1 prec) "|" (HK:PT-KEY p2 prec))
(defun HK:ARC-KEY (edata prec / c r sa ea)
(setq c (HK:SAFE-PT (cdr (assoc 10 edata))))
(setq r (HK:SAFE-NUM (cdr (assoc 40 edata))))
(setq sa (HK:SAFE-NUM (cdr (assoc 50 edata))))
(setq ea (HK:SAFE-NUM (cdr (assoc 51 edata))))
(strcat "ARC|" (HK:PT-KEY c prec) "|"
(rtos (HK:ROUND r prec) 2 6) "|"
(rtos (HK:ROUND sa prec) 2 6) "|"
(rtos (HK:ROUND ea prec) 2 6))
(defun HK:CIRCLE-KEY (edata prec / c r)
(strcat "CIRCLE|" (HK:PT-KEY c prec) "|" (rtos (HK:ROUND r prec) 2 6))
(defun HK:PLINE-KEY (edata prec / verts key)
(setq verts
(mapcar
'(lambda (x) (HK:PT-KEY (HK:SAFE-PT (cdr x)) prec))
(vl-remove-if-not '(lambda (a) (= (car a) 10)) edata)))
(setq key (apply 'strcat (mapcar '(lambda (v) (strcat v "|")) verts)))
(strcat "PLINE|" key)
(defun HK:BUILD-KEY (ent prec / ed typ)
(setq ed (entget ent))
(setq typ (cdr (assoc 0 ed)))
(cond
((= typ "LINE") (HK:LINE-KEY ed prec))
((= typ "ARC") (HK:ARC-KEY ed prec))
((= typ "CIRCLE") (HK:CIRCLE-KEY ed prec))
((= typ "LWPOLYLINE") (HK:PLINE-KEY ed prec))
(T nil)
(defun HK:COLLECT-GEOM ( / ss i ent key lst)
(setq lst '())
'((-4 . "<OR")
(0 . "LINE")
(0 . "ARC")
(0 . "CIRCLE")
(0 . "LWPOLYLINE")
(-4 . "OR>"))))
(if ss
(progn
(setq i 0)
(setq key (HK:BUILD-KEY ent 0.01))
(if key
(setq lst (cons (list key ent) lst))
(setq i (1+ i))
lst
(defun HK:REMOVE-DUPLICATES (lst / sorted prev removed)
(setq removed 0)
(setq sorted
(vl-sort lst
'(lambda (a b)
(< (car a) (car b))
(setq prev nil)
(foreach item sorted
(if (and prev (equal (car item) (car prev)))
(if (and (cadr item) (entget (cadr item)))
(progn
(entdel (cadr item))
(setq removed (1+ removed))
(setq prev item)
removed
(defun HK:P5-FAST-CLEAN ( / data removed)
(princ "\n[Phase 5] Fast duplicate removal (LINE/ARC/CIRCLE/LWPOLYLINE)...")
(setq data (HK:COLLECT-GEOM))
(if data
(progn
(setq removed (HK:REMOVE-DUPLICATES data))
(princ (strcat "\nRemoved duplicates: " (itoa removed)))
;; Purge & Audit
(command "-purge" "All" "*" "N")
(command "_AUDIT" "_Y")
(princ "\n[Phase 5] Completed.")
;;; PHASE 6 RESET LAYER
(setq *p6-core-layers*
("_Grid" "Grid" 8 "Center")
("_Archi" "Architect" 8 "Continuous")
("MAGIC WORD")
("MAGIC WORD")
(setq *p6-layermrg-rules*
("_ARCHI" ("building" "bldg" "elev" "site" "factory" "area"
"door" "window" "wall" "column" "roof"
"floor" "slab" "ramp" "drain"
"sanitary" "toilet" "office" "room"
"highway" "jalan" "road" "park" "parking"
("_Grid" ("grid"))
("_Mech" ("machine" "production" "worker"
"table" "sofa" "furniture" ))
("MAGIC WORD" ("MAGIC WORD" "MAGIC WORD" ))
("MAGIC WORD" ("MAGIC WORD" "MAGIC WORD"))
;;; Create layer if not exists
(defun p6:create-layer (def / doc lays lay)
(if (not (tblsearch "LAYER" (car def)))
(progn
(setq lay (vla-add lays (car def)))
(vla-put-Description lay (cadr def))
(vla-put-Color lay (nth 2 def))
(if (not (tblsearch "LTYPE" (nth 3 def)))
(command "-linetype" "load" (nth 3 def) "acad.lin" "")
(vla-put-Linetype lay (nth 3 def))
;;; Layer name match (case-insensitive)
(defun p6:layer-match (lname key)
(if (and lname key)
(wcmatch (strcase lname) (strcat "*" (strcase key) "*"))
nil
;;; Remove duplicates from list
(defun p6:list-unique (lst / r)
(setq r '())
(foreach x lst
(if (not (member x r))
(setq r (cons x r))
(reverse r)
;;; SAFE merge layers
(defun p6:run-merge-safe (/ doc layers rule target keys hits h layFlag)
;; collect layer names
(setq layers '())
(vlax-for x (vla-get-Layers doc)
(setq layers (cons (vla-get-Name x) layers))
;; process rules
(foreach rule *p6-layermrg-rules*
(setq target (car rule))
(setq keys (cadr rule))
(setq hits '())
;; find matching layers
(foreach h layers
(if (and (/= h "0") (/= h "DEFPOINTS") (not (wcmatch h "*|*"))
(not (wcmatch (strcase h) "*INFINITE*"))) ;; skip INF layers
(foreach k keys
(if (and (p6:layer-match h k) (/= h target))
(progn
;; CHECK LOCK AND FREEZE
(setq layFlag (cdr (assoc 70 (tblsearch "LAYER" h))))
(setq layFlag (if (numberp layFlag) layFlag 0))
(if (= 0 (logand layFlag 20)) ;; ONLY UNLOCK & THAW
(setq hits (cons h hits))
;; remove duplicates
(setq hits (p6:list-unique hits))
(setq hits (vl-remove-if '(lambda (l) (not (tblsearch "LAYER" l))) hits))
(if hits
(progn
(foreach h hits
(if (/= (strcase h) (strcase target))
(progn
;; ONLY merge thaw/unlock/on LAYER
(command "-LAYMRG" "N" h "" "N" target "Y")
(princ (strcat "\n[P6] No layers to merge into " target))
;;; Set all objects BYLAYER
(defun p6:set-bylayer ()
(if ss
(command "_.CHPROP" ss "" "_COLOR" "BYLAYER" "")
;;; Main Phase 6 Entry
(defun HK:P6-RELAYER ( / ss ent i)
(princ "\n[Phase 6] Layer normalization started...")
;; create core layers
(foreach x *p6-core-layers*
(p6:create-layer x)
;; merge layers safely
(p6:run-merge-safe)
;; set all objects BYLAYER
(p6:set-bylayer)
;; --- change all hatch color to 9 ---
(if ss
(command "_.CHPROP" ss "" "_COLOR" "9" "")
(princ "\n[Phase 6] Completed.")
;;; HK-PHASE 7
(defun HK:LOCK-PRODUCTION-LAYERS ( / lay)
(foreach lay
'("_Grid" "_Archi" "MAGIC WORD" "MAGIC WORD" )
(if (tblsearch "LAYER" lay)
(command "-LAYER" "LOCK" lay "")
(defun HK:GREY-UNLOCKED-LAYERS (/ lay name flag)
(setq lay (tblnext "LAYER" T))
(while lay
(setq name (cdr (assoc 2 lay)))
(setq flag (if (numberp (cdr (assoc 70 lay)))
0))
;; bit 4 = locked
(if (= 0 (logand flag 4))
(command "-LAYER" "COLOR" "8" name "")
(setq lay (tblnext "LAYER"))
(defun HK:LOCK-ALL-LAYERS ()
(command "-LAYER" "LOCK" "*" "")
;;; OVERKILL
(defun HK:OVERKILL-ALL ( / ss)
(princ "\n[OVERKILL] Running on entire drawing...")
(vl-load-com)
;; SELECT ALL
(if ss
(progn
;; START OVERKILL
(command "._OVERKILL" ss "")
;; END
(command "")
(princ "\n[OVERKILL] Completed.")
(princ "\n[OVERKILL] Nothing selected.")
(princ)
;;; PHASE 7 READY
(defun HK:P7-READY ( / )
(princ "\n[Phase 7] Finalizing drawing...")
;; purge
(command "-PURGE" "ALL" "*" "N")
;; lock production layers
(HK:LOCK-PRODUCTION-LAYERS)
(HK:PROTECT-LAYERS)
;; grey remaining layers
(HK:GREY-UNLOCKED-LAYERS)
;; CALL OVERKILL
(HK:OVERKILL-ALL)
;; audit
;; regen
(command "_REGENALL")
;; lock all layers
(command "-LAYER" "_T" "*" "")
(command "-LAYER" "_ON" "*" "")
(princ "\n[Phase 7] Completed.")
;;; ENTRY POINT
(defun c:HOUSEKEEPING ( / )
(princ "\n[HOUSEKEEPING] Start...")
(HK:P0-ENV)
(HK:P1-VIEW-UCS-UNITS)
(HK:P2A-PREPARE)
(HK:P2B-BLOCK-EXPLODE)
(HK:P2C-LAYER-RESET)
(HK:P2D-AUDIT)
(HK:P3-ERASE)
(HK:P4-ZMOVE)
(HK:P5-FAST-CLEAN)
(HK:P6-RELAYER)
(HK:P7-READY)
(princ "\n[HOUSEKEEPING] Done.")
(setq defaultFolder (getvar "DWGPREFIX")) ; CURRENT DOCUMENT
(setq savePath (getfiled "Save Housekeeping As" defaultFolder "dwg" 1))
(if savePath
(command "_SAVEAS" "2010" savePath)
(princ)
Replies (8)
Message 2 of 9
chriscowgill7373
Based on a lot of the info within the code, it would appear that it is highly specialized to align with your company's workflows and standards.  Compartmentalizing the various tasks/phases into separate functions can help if at some point you wish to develop a dialog, where you could pick and choose what tasks you want to run on a particular drawing.
I would be concerned about blanket flattening all objects in a file.  When blocks are flattened, their names are changed, so every block in your file would end up with their own unique name.
Is there a reason that you are saving the drawing in the 2010 format?  That can lead to unnecessary bloat and other issues when working in the drawing in more modern versions, especially since the 2010 format is 2 formats old.
Overall, it lokks like it covers a lot, and I hope that it saves you a significant amount of time cleaning up your files.
Christopher T. Cowgill, P.E.
Civil 3D Certified Professional
Civil 3D 2026 on Windows 11
Message 3 of 9
Sea-Haven
Here is a TOGGLE DCL you just supply descriptions in a list and can then determine which say defuns to run, The code returns an answer like (0 1 0 1 0) the 0 means toggle is off, 1 toggle is on so can check each item in list and run the defun's one after another. There is samples at top of code. Just save in a support path or add full path for the Load function.
Ps as you have lots of defuns you may group some under a choice so have added Multiradio buttons for group choice.
Message 4 of 9
pkomatlapalli
Hello, @jwen_lye ,
Just checking in—did the responses shared by @chriscowgill7373 @Sea-Haven  help clarify your question?
If so, please consider clicking the "Accept Solution" button. Doing so helps others in the community find answers to similar issues.
If your question still needs more attention, feel free to reply here with an update. This way, other members can jump in with further suggestions or guidance to help you move forward.
All the best,
Pavan Kumar | Community Manager
Message 5 of 9
jwen_lye
Observer
Observer
first thank you for reading, but my work flow are :
force explode > flatten>purge, so it shouldn't be any block left behind after this,
but im realizing that the file size is slightly bigger than before after i cleanup with my lisp,
is there any way i can do better on this?
Message 6 of 9
jwen_lye
Observer
Observer
thank you for your advice, but my first intense is to auto clean up the drawing like anti virus, but adding options before start seem like good idea too
Message 7 of 9
chriscowgill7373
Sorry, I didn't go back and reread your code, adter you explode blocks, you need to purge their definition from the file, ktherwise its like having them there twice.  Also, some exploded base objects take up more space preexploded entities, just because those items are built more efficiently.
Message 8 of 9
Kent1Cooper
@jwen_lye wrote:
.... the file size is slightly bigger than before ....
If you have any Blocks that are used more than once, and they all get Exploded, then the file size will necessarily increase.  Part of the reason for Blocks is memory savings.
Say you have a Block made up of twelve Lines, and you have that Block Inserted 6 times.  Each Line has all its information [Layer, color, coordinates, any overrides like linetype, etc.] in memory, as part of the Block definition, but only once for each.  Then the Block Insertions take very little -- basically only location, scale factors, rotation, and Layer -- without needing to keep track of information for each part within each Insertion.
If you Explode all those Blocks, instead of holding data about twelve Lines and six Insertions, the drawing now has to contain all the bits of information about 72 Lines.  Even if, for example, they're all on the same Layer, it still has to keep track of the Layer of each one as a separate piece of data.  And the independent end coordinates of each, etc.
I would recommend not Exploding Blocks, if you want to keep the file size down.  I'm not picturing what the advantage of Exploding them could be.
Kent Cooper, AIA
Message 9 of 9
pkomatlapalli
Hello @jwen_lye ,
Did the information provided by @Kent1Cooper  help you and answer your question?
If yes, please click on the "Accept Solution" button. This will assist other community users in finding and benefiting from this information.
If not, please do not hesitate to give an update in this thread so all community members receive an update on the progression of your question, and can suggest next steps that may be helpful for you to achieve what you're looking for.
All the best,
