i can't find out my problem in this lisp
Message 1 of 22
hi everyone
I want to reverse the text by the selected text, but it does not work properly.it's getting error "lentittyp". I tried so many times.kindly help me .its would be really appreciated for the help. kindly mentioned what i did mistake in this lisp
sample text "a" "b" "c" "123"  etc.....
i want to like this - "123" "c" "b" "a" etc.......
(defun c:lop ()
(setq ss (ssget '((0 . "text"))))
(setq ab (sslength ss))
(setq i 0)
(repeat ab
(setq ssn (ssname ss i ))
(setq ent (entget ssn))
(setq asso (cdr (assoc 0 ent)))
(setq rev (reverse (list asso)))
;(entmod rev)
(setq i (+ i 1))
Replies (21)
Message 2 of 22
SeeMSixty7
I'm not 100% sure if you are trying to reverse the values of the text or the text values themselves.
Based on your sample it looks like you just want to reverse the order of a list of string values pulled from a text selection set. To do that try the following.
(defun c:lop ()
	(setq i 0)
	(setq mylist (list)) ; create a list to work with with nothing in it
	(repeat ab
		(setq asso (cdr (assoc 1 ent))) ; used value if dxf 1 to get text value
		(setq mylist (append mylist (list asso))) ;append the text string to the list
		;(entmod rev)
		(setq i (+ i 1))
	(setq revlist (reverse mylist)) ; reverse the list of text
If you want to actually reverse the value of a text string you will need to write a bit more code. The reverse function works on a list of values, not on a string.
Good luck
Message 3 of 22
Kent1Cooper
This:
(assoc 0 ent)
will get you the entity type of something [in this case all "TEXT"], not its text content.  For the text string content, you want:
(assoc 1 ent)
This:
doesn't do anything, since 'asso' is a single item [reversing a list with only one item is...].
If you want to put the strings into a list and reverse it, you will need a (cons) or maybe (append) function involved, somehow, to put each one into the list.  But it's not clear to me what you want -- to merely change the order of the strings in the list, or [suggested by your commented-out (entmod)] to change the contents of the strings themselves to be the contents of other strings?  If the latter, can you do it by just exchanging their positions instead of their content?
Also, the order of the Text objects in (ssget) could be anything, affected by pick order if you pick them separately, or by drawn order if you pick them by a window, or by the sequence along a Fence path if you pick them that way.  What should determine their order in the list?
Kent Cooper, AIA
Message 4 of 22
doaiena
A few lines of code if you want to reverse the text value:
(defun c:ReverseText ( / ss ctr ent ed text)
(if (setq ss (ssget '((0 . "TEXT"))))
(progn
(setq ctr 0)
(repeat (sslength ss)
(setq ent (ssname ss ctr))
(setq ed (entget ent))
(setq text (vl-list->string (reverse (vl-string->list (cdr (assoc 1 ed))))))
(setq ed (subst (cons 1 text) (assoc 1 ed) ed))
(entmod ed)
(setq ctr (1+ ctr))
(princ)
);defun
Message 5 of 22
Kent1Cooper
(setq revlist (reverse mylist)) ; reverse the list of text ....
If that's what's wanted [and I agree, it's not clear], it can be done more simply.  Instead of using (append) to put each one on the back  end of the list, and after the list is finished, (reverse)ing it, just use (cons) to put each one on the front  end of the list, and it won't need reversing.
  (setq mylist (cons asso mylist))
Kent Cooper, AIA
Message 6 of 22
SeeMSixty7
That is true, but the point was to show how to use the reverse function to reverse a list, and that it applies to a list not to a string.
Message 7 of 22
thanks, everyone for replying to my question.
i want to put text reverse order themselves which I attached the picture.
your code is just reverse the text only. anyway i appreciate so much.
Message 8 of 22
thank you so much kent.
your explanation is very helping us those who learning the AutoLISP program. I am grateful to you.
by hussain
Message 9 of 22
Kent1Cooper
MIRROR [with the MIRRTEXT System Variable set to 0].
Kent Cooper, AIA
Message 10 of 22
CodeDing
@Anonymous ,
Kent normally has those good ideas. MIRROR will work assuming you have a MID reference point (which it appears you do). When you do not have a reference point, here's my simple take.
(defun c:LOP ( / iList ssItem e)
(setq iList '())
;get items
(while (setq ssItem (progn (prompt "\nSelect TEXT Item: ") (ssget "_+.:E:S" '((0 . "TEXT")))))
  (setq iList (cons (cons (setq e (ssname ssItem 0)) (getpropertyvalue e "TextString")) iList))
);while
;if more than 1 item, continue
(if (> (length iList) 1)
  (progn
    (foreach x (mapcar 'cons (mapcar 'car iList) (mapcar 'cdr (reverse iList)))
      (setpropertyvalue (car x) "TextString" (cdr x))
    );foreach
  );progn
;else
  (prompt "\n...One or fewer items were selected. No actions taken.")
);if
(prompt "\nLOP Complete.")
(princ)
);defun
Best,
~DD
Message 11 of 22
CodeDing
Due to the nature of my provided example, as an extra layer of "security" you could ask the user if they're ready to swap, instead of automatically committing them to it.. Here would be the updated section:
(setq iList '() g2g nil)
;get items
(while (not g2g) (while (setq ssItem (progn (prompt "\nSelect TEXT Item: ") (ssget "_+.:E:S" '((0 . "TEXT"))))) (setq iList (cons (cons (setq e (ssname ssItem 0)) (getpropertyvalue e "TextString")) iList)) );while (initget 1 "Yes No") (if (eq "Yes" (getkword "\nReady to Swap? [Yes/No]")) (setq g2g t)) );while ;if more than 1 item, continue
Best,
~DD
Message 12 of 22
ronjonp
Here's another 🙂
(defun c:foo (/ _daisy p s)
  ;; RJP » 2019-11-06
  (defun _daisy	(pt l / _d tmp r)
    (defun _d (p l)
      (vl-sort l (function (lambda (r j) (< (distance p (last r)) (distance p (last j))))))
    (setq tmp (_d pt l))
    (while (setq tmp (_d (last (car tmp)) tmp)) (setq r (cons (car tmp) r)) (setq tmp (cdr tmp)))
    (reverse r)
  (if (and (setq s (ssget ":L" '((0 . "text"))))
	   (setq p (getpoint "\nPick a point to sort from: "))
	   (setq
	     s (_daisy
		 p
		 (mapcar '(lambda (x) (list x (cdr (assoc 1 (entget x))) (cdr (assoc 10 (entget x)))))
			 (vl-remove-if 'listp (mapcar 'cadr (ssnamex s)))
    ;; Nice reverse @Codeding :)
    (foreach x (mapcar 'cons (mapcar 'car s) (mapcar 'cdr (reverse s)))
      (entmod (append (entget (car x)) (list (cons 1 (cadr x)))))
  (princ)
Message 13 of 22
Sea-Haven
Removed my idea
How do I delete a post ?
Message 14 of 22
CodeDing
@Sea-Haven ,
I had the same initial reaction, but on looking further OP does not want to sort, but rather reverse the order of items.
The solution provided by @ronjonp is actually quite elegant and, in my opinion, would be a great solution to this post.
Best,
~DD
Message 15 of 22
Sea-Haven
Thanks codeding updated my post just now thought about it a bit more ssget F may simplify code.
This in Civil software is reorder strings. Generally with a new start number.
Message 16 of 22
CodeDing
Lol, I update my posts because of stuff like that all the time.
Message 17 of 22
Sea-Haven
Did not work in Briscad but ok in Autocad ?
Message 18 of 22
hi  R0NJ0NP
your code is really interesting. this is what I was expected from here. i am really grateful to you and everyone who replied to my query.
i have another question here. could i add here for block text?
(ssget ":L" '((0 . "text" "insert")))) "is this correct code for block"
thanks
hussain
Message 19 of 22
Sea-Haven
Very nice Ronjonp but look at image I made the numbers out of order, erased some made a new ones as the ssget uses the database its now out of order. so renumber is incorrect. Providing the numbers are done one after another they are ok.
That's why I hinted some sort of string approach.
Message 20 of 22
Kent1Cooper
@Sea-Haven wrote:
.... I made the numbers out of order, erased some made a new ones as the ssget uses the database its now out of order. so renumber is incorrect. Providing the numbers are done one after another they are ok.
That was exactly my concern at the end of Message 3 -- anything that depends on the order things occur in the selection set can give different results depending on exactly how the selection is made.  But I wonder about a "string approach," if by that you mean to sort into order by text-string content.  The values in the image at Message 7 happen to be in order from one end to the other, but @Anonymous , would that always the the case?
Kent Cooper, AIA
