How to verify empty selection in (SSGET)
arperezinf
arperezinf
Hello 👋
I have a problem with my routine lisp code, it gives me an error when I have no element selected and I press the enter key.
I would like to know how I can make it check if the selection is empty in (ssget) and if it is, repeat (ssget), until there is a selection or the routine is canceled.
I wanted to use an if statement, but I didn't know where to put the statement.
This is the code
(setq linkvalue (itoa value)
  ss      (ssget)
  len     (sslength ss)
  cont     0
  entdata  linkvalue
Thank you very much for reading my message.
Greetings.
ВeekeeCZ
where do you get a "value" from?
are you selecting texts to set "linkvalue" as their contents?
here is an example:
  (if (setq ss (ssget))
    (repeat (setq index (sslength ss))
      (setq entname (ssname ss (setq index (1- index))))
      (setq entdata (entget entname))
      (... do something ...)
      ) ; end of repeat
    ) ; end of if
Kent1Cooper
@arperezinf wrote:
.... I would like to know how I can make it check if the selection is empty in (ssget) and if it is, repeat (ssget), until there is a selection or the routine is canceled.
(setq linkvalue (itoa value))
(while (not (setq ss (ssget))))
(setq len (sslength ss) ....
Kent Cooper, AIA
arperezinf
Hello 👋 @ВeekeeCZ @Kent1Cooper
Thank you very much for your comments.
I ask for the value in another line of code before this part of code that I do not publish and I am using (getint), an integer and I am selecting blocks.
Let me analyze how I implement what they say in my code because I don't know much about visual lisp programming.
Greetings.
arperezinf
Thank you very much to both.🤝
I already managed to do what I needed!😀👌
@Kent1Cooper your code works as I need, it is the solution I was looking for.👏🙏🤝👍
Greetings.
Sea-Haven
Like Kent's answer I often use an alert to show ssget failed.
(if (=(setq ss (ssget)) nil)
(alert "There is no selection set please run again")
The other is a hard exit but have to be careful does not cause problems.
  (progn
    (alert "There is no selection set please run again\nWill now exit")
    (exit)
arperezinf
Thank you very much for your comment, I will keep it in mind.
Greetings.
