@Anonymous wrote:
i am trying:
(setq ename (entget (car (entsel "\nSelect TitleBlock: "))))
(setq name_title (assoc 2 ename))
(if (setq ss (ssget "x" (list '(0 . "INSERT") name_title (cons 410 (getvar "ctab")))))
(progn
That is clear for me.
Can u see it Henrique !
Thanks for your solution
To run the script in a folder, we can't have one of the dwg's in that folder opened... we need to have all dwg's in that folder closed...otherwise the code will error...
If you have a dwg in another folder with the same TitleBlock, you can modify Kent1Cooper's code, as a function with one argumente
i.e.
(defun MyCode (name_title / ll minpt ss)
;; http://forums.autodesk.com/t5/visual-lisp-autolisp?-and-general/update-titleblock-insertion-point-or-?move-border-frame-s-to-the/m-p/6383170#M342043
;; by Kent1Cooper
(vl-load-com)
(foreach layout (layoutlist) ; conveniently returns list of all Paper-space Layouts
(setvar 'ctab layout) ; get into the Layout
(command "_.pspace") ; [in case it might be in Model space through a Viewport in that Layout]
(if (setq ss (ssget "x" (list '(0 . "INSERT") (cons 2 name_title) (cons 410 (getvar "ctab")))))
(progn
(vla-getboundingbox (vlax-ename->vla-object (ssname ss 0)) 'minpt 'maxpt)
(setq LL (vlax-safearray->list minpt)) ; Lower Left corner of block's contents
(command "_.layer" "_thaw" "*" "_on" "*" "_unlock" "*" "" ; make everything movable
"_.move" (ssget "x" (list (cons 410 (getvar "ctab")))) "" LL '(0.0 0.0 0.0)
"_.layerp" ; return previous Layer settings
) ; end command
) ; end progn
) ; end if
) ; foreach
and in the code to write and run the script
;; Load Supporting Functions
;; Old Version of 'BrowseForFolder' by: Tony Tanzillo
(defun BrowseForFolder (Message / sh folder parentfolder folderobject result)
(vl-load-com)
(setq sh (vla-getInterfaceObject (vlax-get-acad-object) "Shell.Application"))
(setq folder (vlax-invoke-method sh 'BrowseForFolder 0 Message 0))
(vlax-release-object sh)
(if folder
(progn
(setq parentfolder (vlax-get-property folder 'ParentFolder))
(setq FolderObject (vlax-invoke-method ParentFolder 'ParseName (vlax-get-property Folder 'Title)))
(setq result (vlax-get-property FolderObject 'Path))
(mapcar 'vlax-release-object
(list folder parentfolder folderobject)
(if (/= (substr result (strlen result)) "\\")
(setq result (strcat result "\\"))
result
(defun c:demo (/ dirpath dwgfile dwglist ent my_lisp_file name_title ofile sel) ; <<< change the command name!!!
(if (and (setq DirPath (BrowseForFolder "Select directory to scan drawings."))
(setq sel (car (entsel "\nSelect TitleBlock: ")))
(= (cdr (assoc 0 (setq ent (entget sel)))) "INSERT")
(setq name_title (cdr (assoc 2 (entget sel))))
(progn
(setq my_lisp_file "MyCode.lsp") ; <<< Place the correct lisp name here!!!
(setq Scrfile (strcat DirPath "test.scr"))
(setq ofile (open Scrfile "w"))
(setq DwgList (vl-directory-files DirPath "*.dwg" 1))
(foreach Dwg DwgList
(setq DwgFile (strcat DirPath Dwg))
(write-line (strcat "_.open\r" (chr 34) DwgFile (chr 34) "\r") Ofile)
(write-line (strcat "(load " (chr 34) my_lisp_file (chr 34) ")") Ofile)
(write-line "(my_lisp_file name_title)" Ofile)
(write-line "_.qsave" Ofile)
(write-line "_.close" Ofile)
(close Ofile)
(command "_.script" Scrfile)
(vla-sendcommand (vla-get-activedocument (vlax-get-acad-object)) "(vl-file-delete Scrfile)\r")
(princ)
But remember, none of the dwg's to process can be open!
Hope this helps,
Henrique
